Home > Faults & Fixes > Vibration under braking
franciscolalas
I've changed my rotors and pads on my RRSport and vibration started (Brembo Calipers on front).
Noticeable when light braking from 80 km/h. Under hard braking vibration is less felt.
First I changed the rear rotors and pads (brembo and mintex) no vibration.
Then i changed the front rotors and pads (brembo and mintex) and vibration started.
Called the parts supplier and they took around 2 month to give me new front rotors. When I removed the front rotors one had a dent from being droped during transportation. Changed the front rotors and vibration didn't go away. Bought new pads and didn't solve the problem. Remove new discs and measured hub to see if it was warped and only 0.005 mm on left and 0.004mm on right hub.
Any clues?
Thanks
Post #404018 Thu Nov 28 2013 12:00am
Paddi
Rotors = discs in the UK just in case anyone is confused by the terms. Thumbs Up
Did you check the run-out with the discs installed? This is what LR give as the limit:
Maximum disc run-out - disc installed 0.05 mm (0.002 in)
If the run-out is within spec. then you need to carefully check all the front suspension components for wear or damage. Particularly the bushes and ball joints.
Those are the most likely causes but here is link to an in-depth description of causes of brake judder:
http://www.powerbrake.co.za/tech_info/tech_01_judder.htm 2008 MY Java Black TDV8 HSE
Post #404094 Thu Nov 28 2013 4:00pm
franciscolalas
I think I got 0.02 and 0.03 mm on the front discs.
Maybe It could be the rears as I didn't checked them yet.
Left the car in the mechanic as it was driving me crazy!
Will update when problem solved.
Thanks.
Post #404104 Thu Nov 28 2013 5:32pm
Paddi
Tolerance for the for the rear disc is greater:
Maximum disc run-out - disc installed 0.09 mm (0.003 in)
Agree brake judder is just Twisted Evil
Hope you get it fixed. 2008 MY Java Black TDV8 HSE
Post #404113 Thu Nov 28 2013 6:08pm
franciscolalas
Against all odds...warped rear disc! Brand new Brembo disc had to be skimmed.
Post #406757 Thu Dec 19 2013 9:35pm
Paddi
Could have been a manufacturing fault but more likely to be a bit of contamination between the disc and hub when fitted.
Glad to hear you have fixed the problem Thumbs Up 2008 MY Java Black TDV8 HSE
Post #406815 Fri Dec 20 2013 12:59pm
