Home > Faults & Fixes > Engine System Fault - Limp mode |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Read this post http://www.disco3.co.uk/forum/topic98502.html
Tue Dec 17 2013 9:01am |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 |
Possibly common if vehicles are not being used as much as they should? |
Tue Dec 17 2013 11:57pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
See it a lot, more so on the TDV8. All it needs is some penetrating oil, sprayed up onto the bottom link bolt, and worked up and down to free off. May take a few goes, but never failed to free one off as yet |
Wed Dec 18 2013 6:40am |
warren203 Member Since: 12 May 2012 Location: warrington Posts: 9 |
Hi mike
Sat Dec 21 2013 3:59pm |
cobbler2u Member Since: 09 May 2010 Location: hertfordshire Posts: 69 |
Same problem as me.
Sat Dec 21 2013 4:21pm |
These are the codes
Sat Dec 21 2013 4:36pm |
PaulHH Member Since: 24 May 2013 Location: Highlands Posts: 98 |
I am getting a similar problem with my Supercharged. Hoped it was the Brake Light Switch but that has been changed. My fault happens only when going up long steep hills. Only ever happens on the same road south of Inverness. I can usually pull over, switch off for 30 seconds and then restart and all is good. Haven't had the codes read yet. 2006 Supercharged |
Mon Dec 23 2013 8:59pm |
Is there a link so we can see & locate these atuator rods? |
Mon Dec 23 2013 9:30pm |
No. If/When I have a TDV8 to look at next, I will take some photos |
Mon Dec 23 2013 9:52pm |
Mon Dec 23 2013 9:53pm |
It turned out to be a split hose in the end. I kept going into limp mode on the way home from manchester from aberdeen, so i called the RAC out. He looked at the codes then made a call, then shown me the split. As simple as that.
Tue Jan 07 2014 1:40pm |
Good news, I like the cheaper fixes. |
Tue Jan 07 2014 2:14pm |
jsamps Member Since: 11 Mar 2014 Location: Nottingham Posts: 12 |
I have a RRS 06 tdv6 and im getting an esf message thats indicating absolute pressure failure (I think the codes p0106) problem is the car is fine and is driving the same as before the message came up! Ive had the map sensor checked,egr valves are fine and also had the turbo looked at cleaned and all seems fine? Anyone else had this before? Even the main stealer cant find out what the cause is! There only solution was to replace the turbo!!!
Wed Mar 12 2014 9:49am |
dukeminster Member Since: 26 Apr 2013 Location: United Kingdom Posts: 29 |
I've heard this turbo actuator is a common problem, however mine had the same symptoms and it turned out to just be that the turbo hose had split. |
Wed Mar 12 2014 10:27am |
