Home > Wheels & Tyres > What is the procedure for taking wheels off an RRS?
Page 3 of 4 <1234>
paulL
Spain 2013 Range Rover Sport SDV6 Autobiography Fuji White
I ALWAYS go to offroad setting on air suspension and tailgate open... As has every dealer/tyre fitter I have ever had touch my RRS! 2013 RRS SDV6 Autobiography Fuji White
2007 RRS TDV8 HSE - gone -
2005 RRS TDV6 HSE - gone -
Post #406342 Mon Dec 16 2013 12:55pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Appreciate that but I was in off road mode with the boot open but the car still did it's own thing. Maybe I've got a fault?
Post #406346 Mon Dec 16 2013 1:48pm
Paddi
^^ That does seem odd (the bit about the car 'sucking the wheel up'). I've jacked up the RRS numerous times for servicing and never seen that happen. As far as I know the suspension extends by gravity and/or air pressure but can't generate negative air pressure in the bag to 'suck' wheels up.
But if anyone know different now's their chance.......
Note the official LR procedure doesn't say anything about leaving doors or tailgates open or hazards on, removing fuses etc; and I've never done any of that.
Just put it in off road height so the jack doesn't have to lift the car to such a high angle and use a jack adapter to positively locate the jack in the chassis rail hole so it can't slip 2008 MY Java Black TDV8 HSE
Post #406347 Mon Dec 16 2013 2:04pm
flydive
Watch this:
My car
. '08 RRS TDV8
Post #406362 Mon Dec 16 2013 4:35pm
mse
It looks more like its releveling which gives the impression its sucking up, but I don't think it is (I know the wheel goes up but that doesn't mean its sucking up Mike
2014 Facelift Discovery
Post #406370 Mon Dec 16 2013 6:13pm
mse
Just watched it again, the other side is moving so its self levelling im sure. Mike
Post #406371 Mon Dec 16 2013 6:14pm
flydive
That's correct, we cannot hide anything to you Mr. Green
Yes, is levelling, but the end effect is the wheel lifting off the ground. '08 RRS TDV8
Post #406373 Mon Dec 16 2013 6:30pm
mse
Its not lifting, its just not dropping Whistle - its staying where it needs Mike
Post #406377 Mon Dec 16 2013 8:06pm
flydive
Well, before it touches the ground, after it does not, that's lifting enough for me.
The wheel is lifting off the ground
How it is accomplished it matters not. '08 RRS TDV8
Post #406379 Mon Dec 16 2013 8:14pm
You engine isn't supposed to be running while jacking your car up though. Its going to try and self level isn't it Question
Post #406384 Mon Dec 16 2013 8:46pm
flydive
Correct, if you lift the car the conventional way.
Doing it the way shown you need the engine running and doors closed, because you use the levelling function to automatically lift the wheel(or have the ground fall away from it Wink )
The way it works, engine running, you put the jack under the lower arm, lift a bit, wait a second and the car will try to level, causing the wheel to get off the ground. Zero effort. '08 RRS TDV8
Post #406385 Mon Dec 16 2013 8:59pm
mse
Its not lifting the wheel though its moving the whole car while leaving the wheel in the same relative position, so the wheel lifts off the ground...but that's nothing to do with that corner of the car, its the other three corners.
Just like when you cross axle the wheel doesn't lift up the other corner (for an example) drops or the ground isn't there. Mike
Post #406392 Mon Dec 16 2013 10:06pm
flydive
Oh man, oh man Rolling Eyes '08 RRS TDV8
Post #406393 Mon Dec 16 2013 10:14pm
mse
were you not trying to demonstrate the car sucking the wheel up as per the posts above? Mike
Post #406396 Mon Dec 16 2013 10:49pm
flydive
No, I never wrote anything about sucking the wheel up.
The video is to show what might look like the wheel being sucked, and to show an alternate way to lift the wheel off the ground.
Whether by the above method, by jacking the car, by dipping one corner in a hole, being strapped to a crane or rolling on the roof, the end result is the car lifting the wheel off the ground.
In the video, if the car was sucking the wheel up, the tyre would never leave the ground. '08 RRS TDV8
Post #406410 Tue Dec 17 2013 7:55am
Page 3 of 4 <1234>
