Home > Wheels & Tyres > What is the procedure for taking wheels off an RRS? |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
Appreciate that but I was in off road mode with the boot open but the car still did it's own thing. Maybe I've got a fault? |
Mon Dec 16 2013 1:48pm |
^^ That does seem odd (the bit about the car 'sucking the wheel up'). I've jacked up the RRS numerous times for servicing and never seen that happen. As far as I know the suspension extends by gravity and/or air pressure but can't generate negative air pressure in the bag to 'suck' wheels up.
Mon Dec 16 2013 2:04pm |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 |
Watch this:
Mon Dec 16 2013 4:35pm |
It looks more like its releveling which gives the impression its sucking up, but I don't think it is (I know the wheel goes up but that doesn't mean its sucking up Mike
Mon Dec 16 2013 6:13pm |
Just watched it again, the other side is moving so its self levelling im sure. Mike
Mon Dec 16 2013 6:14pm |
That's correct, we cannot hide anything to you
Mon Dec 16 2013 6:30pm |
Its not lifting, its just not dropping - its staying where it needs Mike
Mon Dec 16 2013 8:06pm |
Well, before it touches the ground, after it does not, that's lifting enough for me.
Mon Dec 16 2013 8:14pm |
You engine isn't supposed to be running while jacking your car up though. Its going to try and self level isn't it |
Mon Dec 16 2013 8:46pm |
Correct, if you lift the car the conventional way.
Mon Dec 16 2013 8:59pm |
Its not lifting the wheel though its moving the whole car while leaving the wheel in the same relative position, so the wheel lifts off the ground...but that's nothing to do with that corner of the car, its the other three corners.
Mon Dec 16 2013 10:06pm |
Oh man, oh man '08 RRS TDV8
Mon Dec 16 2013 10:14pm |
were you not trying to demonstrate the car sucking the wheel up as per the posts above? Mike
Mon Dec 16 2013 10:49pm |
No, I never wrote anything about sucking the wheel up.
Tue Dec 17 2013 7:55am |
