Home > Wheels & Tyres > What is the procedure for taking wheels off an RRS?
Page 2 of 4 <1234>
mse
firstinretail wrote:
mse wrote:
Sorry, procedure for jacking the car is really important
Its air suspension to MAX height, hazards on. I always was shown to open the windows, but not sure why or if you need to.
Tailgate does not need to be open.
Jack away (avoiding the compressor on the chassis rail)
That's Censored sorry, a door has to be open this disables the suspension, but a door can blow shut so the tailgate is used. Try adjusting the suspension with a door or tailgate open, nothing to do with the windows. Forums are dangerous when wrong info is given out !
Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
There is only one person talking Censored t here!!
If you would like to turn to page 216 of your manual - which i will copy for you later - you will see the instructions.
Jacked many of these up.
The thing that stops the compressor is A) the off road height and b) the Hazards.
The above also stops self levelling
Had a tyre changed at land rover on my 11 and that was the procedure.
Think logically - your at the side of the motorway in the hail/sleet rain...open your door/boot - no.
Your thinking about leaving it at normal height and stopping it raising - but thats not what shags the compressor.
I dont mess around with safety advice...you shouldnt either Thumbs Up Mike
2014 Facelift Discovery
Post #355450 Mon Sep 03 2012 7:59pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
Well good luck mr safety, because I have just checked, my car will go up and down with the hazards on, engine on, it will also lower itself from max with the hazards on with no engine on. (so if someone lent on the button whilest a wheel was off it would lower) the car Won't do either with a door or the tail gate open ?....
So I will stick with the door/tailgate open method, as that 100% disables the compressor. If you took some fog and put it in a jar, would it be missed.
Post #355453 Mon Sep 03 2012 8:12pm
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
Am I missing something?? You put into extended height to fool the compressor, as if you left it in standard height it would never get the wheel off the ground, thinking it was going over a rock?? Can the compressor "suck" the wheel back into the wheel well if left (doors closed/hazards on/windscreen wipers going, whatever.......
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #355457 Mon Sep 03 2012 8:46pm
rrsboy
2010 Range Rover Sport TDV8 HSE Santorini Black
I can't remember who told me the tailgate trick, but I remember them saying how important it was!
Thumbs Up ============
2010 TDV8 HSE - ooo laa laaaaaaaaa
2007 TDV8 HSE - superb car and very reliable
2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8!
Post #355458 Mon Sep 03 2012 8:46pm
mse
Dave
Exactly - it wont pull the wheel back into the well - it cant drop the car because its raised
You can raise and lower the car with the hazards on (i do it for towing with the remote)...that isnt the point (incidentally, you shouldn't do it with the engine running - engine should be off in park etc)
With the engine off you cant lower the car like you describe - no need to mess around with the tailgate Rolling with laughter
Having said that maybe thats why they crack the window
Incidentally - how many of you disable the self levelling when your on the ferry - that shags the compressor if you do it a lot Wink Mike
Post #355461 Mon Sep 03 2012 8:52pm
firstinretail
Well we will have to agree to disagree, I have just sat in the car engine off and I CAN lower it, can't with a door open. If you took some fog and put it in a jar, would it be missed.
Post #355462 Mon Sep 03 2012 9:22pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
My P38 won't move on its air suspension if a door or tailgate is open, neither will the RRS (05). Think of it, door open, suspension drops, door crashes onto kerb or anything else that could be in the way Wink
The owner's manual states that the suspension should be in off road mode prior to jacking. No reference to open doors or tailgate. There is a mention of the hazard (as well as the warning triangle), I suspect this is more to do with the safety of being seen to be stranded rather than anything to do with the suspension.
Do you lock it into access mode to achieve this, run the hazards during the crossing or leave a door/tailgate open ?
"Roads ? Where we're going there are no roads." Back to the future.
Post #355466 Mon Sep 03 2012 10:00pm
shakeapaw
Just to further confuse things,( i read my manual after i had changed a wheel ), i jacked mine up in normal mode, no doors/tailgate open, no hazards on, just jacked it up like a normal car, changed the wheel, and drove off, no dramas, no suspension faults, no nothing 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #355599 Wed Sep 05 2012 10:19am
mrfrog
To be fair, I doubt that the one-off occurrence of lifting a wheel to change it is likely to cause any serious damage to the compressor, rather the advice is given to make the job easier: get the compressor to do the hard work of lifting the car as high as possible, then use the jack to get the wheel off the ground.
This is easier than lifting the vehicle through the whole suspension travel on the jack before the wheel will even start to lift.
Post #355601 Wed Sep 05 2012 10:40am
ranco18972
United States 2007 Range Rover Sport 4.4 V8 HSE Luxury Santorini Black
I highly recommend that you order the Range Rover 200x-2009 Repair manual.
I just got it and it has everything you need to know about RR maintenance.
Go to ebay and you will find it.
Post #357360 Fri Sep 21 2012 1:41am
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Ok, so I needed to swap 2 front wheels last night, vehicle was put into off road mode (1 click up) and I opened the tailgate. As I jacked the car up and got almost to the point where the wheel left the floor the car decided to suck the wheel into the arch, giving me a bit of a scare as I was pretty close. This seems pretty dangerous to me, can anyone say for certain what the correct procedure for jacking is? Do the hazards really percent this happening? Incidentally, when I changed the other side there was no problem??
Post #406316 Mon Dec 16 2013 8:48am
Tony666
Prevent not percent......predictive text Whistle
Post #406317 Mon Dec 16 2013 8:50am
So what procedure do the dealers use Question Ive seen them drive the vehicle into the two post ramp using the swing out arms, and just lift the vehicle, not opening any doors or tailgate and not putting the hazard lights on. If anyone should know the correct procedure they should. When i'm changing my wheels over i raise the vehicle into full height mode then put it into P, put handbrake on, leave a door and tailgate open, then crack on changing the wheels. Thumbs Up
Post #406321 Mon Dec 16 2013 9:39am
Tony666
I've little faith in main dealers! They should know the correct procedure but that doesn't mean they always follow it! I had an Audi previously that had a problem with the front suspension. The Audi dealer had put the mount in upside down, picked up by an old mechanic charging a hell of a lot less than the 'main dealer'. Maybe I'll contact Land Rover for the answer, though I feel it should be a lot clearer considering the damage/injury that could result from changing a wheel!!
Post #406328 Mon Dec 16 2013 10:38am
Paddi
In the tech section there's a link to the Disco 3 workshop manual and that includes jacking procedure:
http://landrover.workshop-manuals.com/lr3/index.php?id=85 2008 MY Java Black TDV8 HSE
Post #406335 Mon Dec 16 2013 11:23am
Page 2 of 4 <1234>
