Home > Wheels & Tyres > What is the procedure for taking wheels off an RRS? |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 |
Well good luck mr safety, because I have just checked, my car will go up and down with the hazards on, engine on, it will also lower itself from max with the hazards on with no engine on. (so if someone lent on the button whilest a wheel was off it would lower) the car Won't do either with a door or the tail gate open ?....
Mon Sep 03 2012 7:12pm |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
Am I missing something?? You put into extended height to fool the compressor, as if you left it in standard height it would never get the wheel off the ground, thinking it was going over a rock?? Can the compressor "suck" the wheel back into the wheel well if left (doors closed/hazards on/windscreen wipers going, whatever.......
Mon Sep 03 2012 7:46pm |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
I can't remember who told me the tailgate trick, but I remember them saying how important it was!
Exactly - it wont pull the wheel back into the well - it cant drop the car because its raised You can raise and lower the car with the hazards on (i do it for towing with the remote)...that isnt the point (incidentally, you shouldn't do it with the engine running - engine should be off in park etc) With the engine off you cant lower the car like you describe - no need to mess around with the tailgate Having said that maybe thats why they crack the window Incidentally - how many of you disable the self levelling when your on the ferry - that shags the compressor if you do it a lot Mike 2014 Facelift Discovery |
Mon Sep 03 2012 7:52pm |
Well we will have to agree to disagree, I have just sat in the car engine off and I CAN lower it, can't with a door open. If you took some fog and put it in a jar, would it be missed. |
Mon Sep 03 2012 8:22pm |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
My P38 won't move on its air suspension if a door or tailgate is open, neither will the RRS (05). Think of it, door open, suspension drops, door crashes onto kerb or anything else that could be in the way
Do you lock it into access mode to achieve this, run the hazards during the crossing or leave a door/tailgate open ? "Roads ? Where we're going there are no roads." Back to the future. |
Mon Sep 03 2012 9:00pm |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
Just to further confuse things,( i read my manual after i had changed a wheel ), i jacked mine up in normal mode, no doors/tailgate open, no hazards on, just jacked it up like a normal car, changed the wheel, and drove off, no dramas, no suspension faults, no nothing 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Wed Sep 05 2012 9:19am |
To be fair, I doubt that the one-off occurrence of lifting a wheel to change it is likely to cause any serious damage to the compressor, rather the advice is given to make the job easier: get the compressor to do the hard work of lifting the car as high as possible, then use the jack to get the wheel off the ground. This is easier than lifting the vehicle through the whole suspension travel on the jack before the wheel will even start to lift. "Roads ? Where we're going there are no roads." Back to the future. |
Wed Sep 05 2012 9:40am |
ranco18972 Member Since: 10 Sep 2012 Location: Illinois Posts: 9 |
I highly recommend that you order the Range Rover 200x-2009 Repair manual.
Fri Sep 21 2012 12:41am |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
Ok, so I needed to swap 2 front wheels last night, vehicle was put into off road mode (1 click up) and I opened the tailgate. As I jacked the car up and got almost to the point where the wheel left the floor the car decided to suck the wheel into the arch, giving me a bit of a scare as I was pretty close. This seems pretty dangerous to me, can anyone say for certain what the correct procedure for jacking is? Do the hazards really percent this happening? Incidentally, when I changed the other side there was no problem?? |
Mon Dec 16 2013 7:48am |
Prevent not percent......predictive text |
Mon Dec 16 2013 7:50am |
So what procedure do the dealers use Ive seen them drive the vehicle into the two post ramp using the swing out arms, and just lift the vehicle, not opening any doors or tailgate and not putting the hazard lights on. If anyone should know the correct procedure they should. When i'm changing my wheels over i raise the vehicle into full height mode then put it into P, put handbrake on, leave a door and tailgate open, then crack on changing the wheels. |
Mon Dec 16 2013 8:39am |
I've little faith in main dealers! They should know the correct procedure but that doesn't mean they always follow it! I had an Audi previously that had a problem with the front suspension. The Audi dealer had put the mount in upside down, picked up by an old mechanic charging a hell of a lot less than the 'main dealer'. Maybe I'll contact Land Rover for the answer, though I feel it should be a lot clearer considering the damage/injury that could result from changing a wheel!! |
Mon Dec 16 2013 9:38am |
In the tech section there's a link to the Disco 3 workshop manual and that includes jacking procedure:
Mon Dec 16 2013 10:23am |
