Home > General > PLEEEEEASE HELP RRS SUDDEN DEATH! |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
Alternator on the way out........? |
Sun Dec 15 2013 2:38pm |
What tests did the AA guy do?
Sun Dec 15 2013 2:55pm |
theforman Member Since: 02 Mar 2012 Location: wolvo Posts: 16 |
thankx for the quick response, we had a new battery two months ago and i checked that the battery was good and checked voltage yesterday and the voltage on the red battery wire was reading 14.2 with a load on,
Sun Dec 15 2013 2:58pm |
according to wifey he turned up lifted the bonnet looked at wires and then started it up n the wfey asked what was the cause he repled by scratchng his head and said he couldnt find anything, he did no battery test or anything else, no codes on car
Sun Dec 15 2013 3:03pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
Sounds like the alternator needs replacing. 2014 L405 SDV8 RR Autobiography
Sun Dec 15 2013 3:26pm |
So many things could cause the car to stop, its difficult.
Sun Dec 15 2013 3:27pm |
Agree it could be something to do with a failing alternator but you could try some simpler things first.
Sun Dec 15 2013 3:34pm |
it only died the once, battery light came on the way to work and on the way home from work but then she came to a t juncton to turn rght, within a splitt second pulling off it cut out, everything went off, no power nothing, she did try a few attempts to start but there were no ignition lights and couldnt even put on the hazards, AA man looked under bonnet di nothing then he turned the key and then it started he was confused as we were, he couldnt see a fault, anyway he sent her on her journey home wthout any problems its just so strange i have read on these rr forums and a few have related this as faulty diodes or some sort in the alternator, i just want a bit more clue on this before i buy a new alternator |
Sun Dec 15 2013 4:04pm |
im ringing land rover tomorrow to take a look at it,
Sun Dec 15 2013 4:13pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Correct me if I am wrong but if the car stops for whatever reason & is left in `D` does that not cut out all power ? Im away from the Sport at the moment so can not confirm - but Mrs Peach has called me once or twice to say the cars dead - wont start -it has been left in `D` or `R `. I appreciate this does not solve the original problem but we all panic when the motor suddenly chimes or flashes up a fault.
Sun Dec 15 2013 4:28pm |
paulL Member Since: 20 Dec 2005 Location: Barcelona Posts: 263 |
I agree. If the car was left in D and the AA man moves it to P then tries starting it, that would explain how it then worked for him. But not why it stopped in the first place! I would say poss alternator... 2013 RRS SDV6 Autobiography Fuji White
Sun Dec 15 2013 4:34pm |
That would only stop it from starting, you would still get ign lights and hazards would always work.
Sun Dec 15 2013 5:48pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
I had a similar issue after changing the battery and the car was completely dead. Turned out that although the terminals on the battery were tightened, the positive wasn't pushed down far enough. A gentle knock with a hammer and all was well. Worth a go |
Sun Dec 15 2013 7:52pm |
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 |
If it was the alternator, then the battery would run itself down to nothing, it would not restart, im betting loose terminal.
Sun Dec 15 2013 10:08pm |
