Home > Technical > found my air suspension leak.... need to know what to do now |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
I would just undo it and see if the pipe is split if not clean it up and try it again to see if it leaks..I have used ptfe tape on these joints to seal them..
Mon Dec 09 2013 2:45pm |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 |
thanks, i was going to suggest ptfe tape but did'nt want to get shot down lol
Mon Dec 09 2013 2:49pm |
Good luck with air drier as most I have done are to far gone and you end up with a new compressor..
Mon Dec 09 2013 2:51pm |
hmm well if thats the case, i wont bother as compressor works fine just it wont go into access mode |
Mon Dec 09 2013 5:24pm |
does anyone know where i can get an olive (presuming the fitting onto the airbag has an olive inside to hold the plastic pipe) |
Mon Dec 09 2013 5:25pm |
is the pipe work 4mm or 6mm to the rear air bags? |
Mon Dec 09 2013 5:30pm |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 |
is there an error saying why it won't go into access mode ? ie. obstruction? RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Mon Dec 09 2013 6:29pm |
what on the dash? ive not had it plugged in, i'll have to check but it says raising to extended mode deffinately |
Mon Dec 09 2013 7:14pm |
yes, an error usually displays on the dash RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Mon Dec 09 2013 7:53pm |
hi b3eee
Mon Dec 09 2013 8:47pm |
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 |
which means your compressor is goosed |
Mon Dec 09 2013 10:12pm |
Plenty of people have changed compressor for this and its still caried on. Thing is it goes up and down in seconds on all other modes. If compressor needs replacing ill just leave it. I can live without access to gain £500 |
Mon Dec 09 2013 10:32pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Is this vehicle second hand? If so, someone might have played with the EAS settings, e.g. with an IIDTool, so that access height sits it on its bump stops before it gets fully down (as far as it considers fully down). 2012 SDV6 - it's missing a couple of cylinders
Mon Dec 09 2013 11:03pm |
Yes it is secondhand. |
Mon Dec 09 2013 11:14pm |
