Home > Technical > found my air suspension leak.... need to know what to do now
B3EEE
Wales 2005 Range Rover Sport Supercharged Vesuvius Orange
it's not compressor, as mine is still doing this even after new one fitted, plus new front height sensors, new front arch wiring etc. I've given up too, as never need to change height settings. LR now saying it may be the rear sensors, sending a false reading to the front, sounds daft to me though.
Try this, do the same thing when moving slowly forward, as mine lowers and raises 100% perfectly when moving, but not at stand still  RR Sport Supercharged Vesuvius Orange 4.2 V8 First edition
Prefer RR Vouge S/C but they don't do Orange !
Post #405546 Mon Dec 09 2013 11:21pm
mse
Or one of the sensors is shafted or adjusted as mentioned previously. Mike
2014 Facelift Discovery
Post #405618 Tue Dec 10 2013 5:51pm
shadrack
is there any diy scanner programs for land rover ive had bmws for 10 years and have bmw1.4.0 and inpa so can do all my own fauld codes, suspension adjustments etc myself, just need similar for landrover
Post #405643 Tue Dec 10 2013 8:56pm
Bodsy
Site Sponsor
Blackbox solutions MSV2 I use for d3, d4, RRS
They've just launched a Nanocom version that is much cheaper. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #405644 Tue Dec 10 2013 9:00pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
The air hose is 6mm. If you can't get a fitting, PM me and I can maybe help out.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #405665 Wed Dec 11 2013 1:20am
drdelrrs
Part of the suspension design is that if you're driving and the car detects something under the chassis etc it will raise to extended mode to clear the obstacle.
This is why, when jacking the car, you need to 'lock' the ride height because if you jack under the chassis the car will attempt to rise. If your car is thinking it has hit something as it goes into access mode, (i.e. the bumps stops, or a faulty ride height sensor or because, as mentioned above, someone played with the settings) it will try and go to 'extended'.
Its probably nowt to do with your compressor's performance if it is raising and lowering relatively quickly.
Post #405678 Wed Dec 11 2013 9:42am
