Home > General > range rover sport ford engine ?? |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1829 |
Do you object to Ford? 2023 P440e SE Dynamic on order -cancelled
Sun Dec 08 2013 3:23pm |
urimg Member Since: 01 Dec 2013 Location: Firenze Posts: 20 |
yess
Sun Dec 08 2013 3:34pm |
No, the 3.0 litre SDV6 engine is superb!! 2023 P440e SE Dynamic on order -cancelled
Sun Dec 08 2013 4:19pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Do a search on Google
Sun Dec 08 2013 4:42pm |
http://en.wikipedia.org/wiki/Ford_AJD-V6/PSA_DT17 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Sun Dec 08 2013 4:43pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1940 |
Isn't it a Lion V6 developed jointly by Ford and Peugeot? It's a brilliant smooth engine. I drive an X5 40D, great car but the RRS TDV6 is smoother than the BMW, not bad for a Ford! Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Mon Dec 09 2013 1:37am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
All Landrover products now have Ford engines - D3/D4/RRS since introduction, Defender from about 2007 with the Puma and RR from about 2007.
Mon Dec 09 2013 2:47am |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
you could say it is a PSA engine |
Mon Dec 09 2013 7:17am |
Historically Ford were the first manufacturers to build engines with 'balanced' parts (1960s) !!
Mon Dec 09 2013 6:46pm |
Stephen J Member Since: 28 Oct 2013 Location: Amsterdam Posts: 16 |
Enginewise, Ford-powered LR's (diesel being PSA-Ford) must be the most reliable yet. Go and ask the FFRR-owners (2002-2005?) what they think. But go ahead and sell it, if you hate Ford that much..
Mon Dec 09 2013 7:00pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8970 |
You could but you'd be wrong. It was designed and developed by Ford in partnership with PSA along with several brands that were part of Ford's stable at the time. In the final analysis it's a Ford engine; and it's no worse for being so. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Mon Dec 09 2013 10:58pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Think in hind sight I would have preferred the ford V6 to the LR developed V8! The V6 is used in several models where as the v8 is only fitted to Range Rover brand so was under engineered and r&d was stunted. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Dec 10 2013 9:05am |
Are you talking petrol V8 or TDV8.
Tue Dec 10 2013 9:15am |
TDV8. And may I respectfully suggest you do a bit more research before publishing your lack of knowledge on open channel. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Dec 10 2013 9:22am |
