![]() | Home > Maintenance & Modifications > Gearbox filter change on a TDV8 2008. |
Is the kit the one with metal pan and separate filter to replace your original plastic pan with integral filter? If so, you will find loads of informative posts on this conversion over on the Disco3 site. IIRC the kits are designed for BMWs hence there are differences in the bolt length. 2008 MY Java Black TDV8 HSE
jong1910 Member Since: 17 Nov 2013 Location: Liverpool Posts: 5 ![]() ![]() ![]() |
Many thanks for that |
