Home > Maintenance & Modifications > NSF "Squeaking" after turing off the engine
I'm getting a squeak squeak squeak noise from the front left of the car that carries on for approx 10 seconds after the engine is turned off (probably squeaking all the time but with the engine going it's being drowned out)
Is this some kind of pulley bearing or belt getting tired? RRS gone
Post #283188 Thu Dec 16 2010 3:19pm
Endjin
Scotland
Could it be the air suspension settling after the car is turned off? 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #283202 Thu Dec 16 2010 4:41pm
Like a compressor bearing or something like that... hmmm could be.. RRS gone
Post #283203 Thu Dec 16 2010 4:42pm
anthony-apl
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
The FBH is there too could it be that 16 model year yulong white autobiography
Bentley continental GTC
2011 VW Transporter T5 Kombi 140BHP with sport line kit for work
15 model year black RRS HSE gone
11MY Fuji White 3.0 TDV6 HSE
Ivory premium leather
Ebony contrast stitching
Extended leather pack
Anigra Wood now gone
08MY Range Rover Sport TDV6 GONE
Post #283210 Thu Dec 16 2010 10:00pm
Bradders
Mine does exactly this too. Ive no idea why! FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #283212 Thu Dec 16 2010 10:12pm
Sporting Chance
England 2010 Range Rover Sport TDV8 HSE Santorini Black
Decided to resurrect this thread as my RRS also appears to have developed this intermittent squeak.
Anyone have any ideas what it could be or do I have a budgie living under the bonnet?
It doesn't appear to make the noise when the engine is running.
SC Current 2010 RRS TDV8
Gone 2009 D3 HSE TDV6
Gone 50th anniversary Defender
Gone 1992 Defender 200 TDI
Gone 1988 Defender TD
Gone 1979 Series 111 V6 Steve Parker conversion
Post #404901 Thu Dec 05 2013 7:33am
It's your EGR valves cleaning themselves
Thumbs Up RRS gone
Post #404913 Thu Dec 05 2013 9:39am
muddywheels
Milk Float Man
I double took then - thought you'd come back to the fold with a RRS until I saw the date Laughing Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #404915 Thu Dec 05 2013 9:45am
Mr. Green
Not just yet... Whistle RRS gone
Post #404922 Thu Dec 05 2013 10:14am
outback4x4uk
What you might find it to be is the variable vane turbo actuators cycling, they do it every time the ignition is turned on and off about 5 times each if memory is correct.
It could be you have one going dry and making the noise, the passenger side is the common one to stick first...mine did the same thing Thumbs Up 08 RRS TDV8 stornoway grey.
06 RRS TDV6 hse Rimni red-----gone!
05 D3 TDV6 se Alveston Red----gone and missed!
53 D2 TD5 xs Epsom Green-----gone!
99 D2 TD5 xs Epsom Green-----gone!
96 D90 300tdi rioja Red---------gone and missed!
Many more come and gone.
Post #404980 Thu Dec 05 2013 2:27pm
Sporting Chance
Is there a remedy for it? Current 2010 RRS TDV8
Post #405001 Thu Dec 05 2013 6:17pm
shadrack
yes, ear plugs Whistle
Post #405019 Thu Dec 05 2013 9:20pm
Sporting Chance
What about 2 stroke in the tank?
Interestingly since its got a little damper the budgie has gone quiet...... Current 2010 RRS TDV8
Post #405028 Thu Dec 05 2013 11:20pm
outback4x4uk
Well if its the actuator rod joints then yes there's a diy and dealer fix, if its the EGR valves as awd man suggested then no quick diy fix, but they can be replaced.
As for the rods its a case of getting underneath removing the engine undertray and locating the servo motors on the turbos, (there about as round as a coke can and about a third as long)
One thing you can try to locate them, if there not seized, is get someone to cycle the ignition while you look underneath with a torch you should see the rods moving back and forth about an inch they are difficult to spot though.
What you need to then do is lubricate the ball joint on the end of each rod..one per turbo...the easiest way I found was to get a can of lube (I used wd40) and attached a length of small bore pvc hose to the nozzle and the other end zip tied to the end of a length of sturdy wire long enough to reach the joints ( I used a wire coat hanger ) then give them a few short bursts of lube and cycle the ignition again to help penetrate.......button back up...job done. Thumbs Up
Another more costly option I did hear about was that the dealers can now replace the rods or ball joints for ones that don't rust, not sure where I read that, but before, they just used to change the offending whole turbos for quite a large fee.
One thing to note is they first squeak when they start to seize, then you loose power as they fully sieze up and finally the engine fault light comes on and you loose lots of power..depending what position the rods have stuck at.
If I remember correctly the egr valves also cycle like the variable vane actuators do in an attempt to keep themselves clean and free, so the path of least resistance would be check rods first then if there ok then maybe it could be the egrs or something different that someone else will be along soon to point out, ...as not all symptoms point to the same ailments Thumbs Up 08 RRS TDV8 stornoway grey.
Post #405080 Fri Dec 06 2013 1:42pm
Sporting Chance
Thanks outback Thumbs Up Current 2010 RRS TDV8
Post #405234 Sat Dec 07 2013 4:50pm
