Home > Maintenance & Modifications > NSF "Squeaking" after turing off the engine |
I'm getting a squeak squeak squeak noise from the front left of the car that carries on for approx 10 seconds after the engine is turned off (probably squeaking all the time but with the engine going it's being drowned out)
Thu Dec 16 2010 3:19pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Could it be the air suspension settling after the car is turned off? 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Thu Dec 16 2010 4:41pm |
Like a compressor bearing or something like that... hmmm could be.. RRS gone
Thu Dec 16 2010 4:42pm |
anthony-apl Member Since: 07 Oct 2007 Location: sunny stockport Posts: 259 |
The FBH is there too could it be that 16 model year yulong white autobiography
Thu Dec 16 2010 10:00pm |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Mine does exactly this too. Ive no idea why! FF 4.4 V8 Soooo looking forward to this bad boy
Thu Dec 16 2010 10:12pm |
It's your EGR valves cleaning themselves
Thu Dec 05 2013 9:39am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5636 |
I double took then - thought you'd come back to the fold with a RRS until I saw the date Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Thu Dec 05 2013 9:45am |
Thu Dec 05 2013 10:14am |
outback4x4uk Member Since: 06 Oct 2011 Location: shropshire Posts: 13 |
What you might find it to be is the variable vane turbo actuators cycling, they do it every time the ignition is turned on and off about 5 times each if memory is correct.
Thu Dec 05 2013 2:27pm |
Sporting Chance Member Since: 08 Aug 2013 Location: Oxford Posts: 32 |
Is there a remedy for it? Current 2010 RRS TDV8
Thu Dec 05 2013 6:17pm |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 |
yes, ear plugs |
Thu Dec 05 2013 9:20pm |
What about 2 stroke in the tank?
Thu Dec 05 2013 11:20pm |
Well if its the actuator rod joints then yes there's a diy and dealer fix, if its the EGR valves as awd man suggested then no quick diy fix, but they can be replaced.
Fri Dec 06 2013 1:42pm |
Thanks outback Current 2010 RRS TDV8
Sat Dec 07 2013 4:50pm |
