Home > Technical > turbo
littlemotherbear71
England 2007 Range Rover Sport TDV8 HSE Siberian Silver
turbo
How do I locate the turbo hoses on our tdv8?
Lost power and theres a ton of black smoke and last time it was a cracked turbo hose hose though there was no loss of power then! I'd like to try to check the problem before spending money on something the mechanic says is at fault then later appears to be something totally different!
Any help on fault suggestions or how to access the turbo hoses hoses would be great! Thanks
This car is more expensive than the kids! !! Big Cry
Post #404839 Wed Dec 04 2013 4:02pm
There are two large pipes at the top of the engine bay that lead from the intercooler to the air inlet manifold. They look like radiator hoses. Check that they aren't split. 2012 SDV6 - it's missing a couple of cylinders
Post #404860 Wed Dec 04 2013 7:42pm
littlemotherbear71
Thankyou very much, I'll check in the morning and post back what I find
Post #404867 Wed Dec 04 2013 8:11pm
littlemotherbear71
Well....
We checked the hoses, no splits or leakage coming from either one... ....
Now wondering if there's an issue with a different hose....? Better than byst turbo! Theres no white smoke, its billowing black smoke on acceleration but with loss of power. ..
Its bugging me!
Sad
Post #404927 Thu Dec 05 2013 10:21am
Does sound like something causing loss of air resulting in over fuelling (hence the black smoke). Could be the intercooler itself that is damaged or one of the hoses from the turbo to the intercooler - these are somewhat deeper in the engine bay so not sure how you would check them without a ramp. 2012 SDV6 - it's missing a couple of cylinders
Post #404939 Thu Dec 05 2013 10:50am
littlemotherbear71
Thanks, time for a mechanic! I'll post back with the result! Its one thing after another with this one! Keeps slipping out of transmission too! Had 2 oil changes and a gearbox rebuild and still slips out! Had different mechanics too lol!
Used to only slip out in automatic but then started to do it in manual. Worse towing and uphill.
Thinking it's got to be an electrical issue now. ..
IIn the back of my mind I'm thinking that once it's driving without black smoke it may be time to replace this 2007 model! !!!!
It's been an expensive one since we got it but once you start spending money on it you get to thinking that it would have been a waste if you give up on it! So you do a bit more, thinking it will be fine this time, then something else happens! !!
Evil or Very Mad
Post #404946 Thu Dec 05 2013 11:22am
Disco_Mikey
For your gearbox fault, look here: Autobox Gearlever Pivot
For your smoke, if you can't see a split, take the hose off and check the hose properly. Very common issue, and 99% of the time, thats what it is Thumbs Up
Post #404963 Thu Dec 05 2013 12:08pm
littlemotherbear71
Been to a range rover mechanics in team valley. ...
The hose had blown off from the turbo to the intercooler!
He sorted it out and toped up the oil. ...
FREE OF CHARGE! !!
It's getting a full service next week! I bet thats not going to be free of charge! Lol
I did find a 2009 intercooler on eBay for £89.50! Plus vat and
Free delivery!
Very Happy
Post #404964 Thu Dec 05 2013 12:09pm
littlemotherbear71
Thanks for all your help! Now to replace and rewire the horn on a 1994 rav4! But thats another story and a different forum! Lol
Rolling with laughter
Post #404965 Thu Dec 05 2013 12:12pm
Excellent result! Thumbs Up
That's the sort of service that gets you going back to them next time even when you know the bill might be big. 2012 SDV6 - it's missing a couple of cylinders
Post #404976 Thu Dec 05 2013 1:37pm
