Home > Maintenance & Modifications > Sport Dynamic Control Module error
amirmughal
Kenya 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Hi, Need some advise on my DTC's being experienced since I did a major service on my Sport 06. Replaced most of the service items like Timing Belt, High Pressure Belt, Alternator, Starter, waterpump and Thermostat housing, Gearbox Oil Filter and Fresh Oil in Transmission.
The car started well and ran many kilometres before I decided to attach a Launch X431 Pro to it. Was shocked to see many errors come up, including a F in the dash display! The most persistent errors that are not clearing up are:
U0122 - lost communication with Dynamics Control Module
C1A00 - Control Module permanent error
Park Brake Fault -
HDC Fault - system not available
I dont see any errors on the System Check while starting car and also it runs well. These erros only appear when connecting a scanner. I tried also the ortiginal SDD software and it showed same errors.
What is the Dynamics Control Module and how can this error be rectified. Seems an electrcial issue ? We had removed many cabkle and sockets during the above service procedures ... not sure if this could be a casue or my DCM needs replacement?
Please assist as I spend many weeks doing major work on my car and am disappointed now on these faults not going away, even after sveeral resets.
Many thanks,
AM Amir Mughal
RRS 2206, Zambezi Silver, HSE, Love My Ride Amir Mughal
RRS 2006, Zambezi Silver, HSE, FACE LIFT 2012
Post #404554 Mon Dec 02 2013 8:40am
Paddi
The Dynamics Control Module is the module that controls the air suspension.
U012287 - Lost
Communication
With Vehicle
Dynamics Control
Module
Note that lost comms fault codes are often found when there is no fault.
Possible causes:
CAN bus fault
ABS module disconnected
ABS module not configured
ABS module failure
C1A000 - Parking Brake Module Fault
Possible causes:
Voltage too low
Vehicle started with booster battery pack (voltage too high)
Module overheating due to 15 or more uses in short time.
Wiring fault - open circuit or short to ground
Park Brake Fault
Assume this is a message on the dash?
Clean and adjust the park brake shoes?
Check park brake functions?
Again assume this is message on the dash
Frequently associated with low battery voltage
Try charging or changing battery?
Maybe some of this will point you in the right direction?
Good luck 2008 MY Java Black TDV8 HSE
Post #404731 Tue Dec 03 2013 5:14pm
amirmughal
Fault Checks
Thanks very much for your valued reply.
I am checking on these later today and have both a Launch scanner and SDD software at hand.
Back will results shortly.
CHEERS Amir Mughal
Post #404793 Wed Dec 04 2013 7:16am
