Home > Technical > Just flashed transmission ECU with IID |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
I have low speed clunks and bumps, I have had the adaptation reset and the box flushed, but it still does it.
Mon Nov 25 2013 8:06pm |
H16UUP Member Since: 23 Aug 2010 Location: Stockport Posts: 31 |
Fraid my IID is locked to my VIN only, but if you have a IID, they might let you be a beta tester? 2006 TDV6 SE, Zermatt Silver |
Mon Nov 25 2013 8:07pm |
That's a as you are only up the road.
Mon Nov 25 2013 8:43pm |
That's pocket money when you're running these beasts 2006 TDV6 SE, Zermatt Silver |
Mon Nov 25 2013 8:45pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Ive sent an EMail off asking about this software, will keep you posted In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Tue Nov 26 2013 1:58pm |
Kenzi Member Since: 24 Jun 2013 Location: Perth Posts: 101 |
How do you reset the gearbox adaption to your driving style? |
Wed Nov 27 2013 12:51pm |
Just drive with your normal driving style 2006 TDV6 SE, Zermatt Silver |
Wed Nov 27 2013 12:52pm |
You can reset the adaptive transmission with the IIDTool. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Wed Nov 27 2013 12:55pm |
Just had an E Mail back from GAP, unfortunately Windows mail will not open it fully, however the part I can read states it's a case of Beta testing & Beta software, so yes I'm all for it, so will send another E Mail off to Gap. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Wed Nov 27 2013 12:57pm |
H16UUP
Sat Nov 30 2013 5:16pm |
