![]() | Home > Technical > Just flashed transmission ECU with IID |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 ![]() ![]() ![]() |
I have low speed clunks and bumps, I have had the adaptation reset and the box flushed, but it still does it.
H16UUP Member Since: 23 Aug 2010 Location: Stockport Posts: 31 ![]() ![]() ![]() |
Fraid my IID is locked to my VIN only, but if you have a IID, they might let you be a beta tester? 2006 TDV6 SE, Zermatt Silver |
That's a |
That's pocket money when you're running these beasts |
Ive sent an EMail off asking about this software, will keep you posted |
Kenzi Member Since: 24 Jun 2013 Location: Perth Posts: 101 ![]() ![]() |
How do you reset the gearbox adaption to your driving style? |
Just drive with your normal driving style |
You can reset the adaptive transmission with the IIDTool. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Just had an E Mail back from GAP, unfortunately Windows mail will not open it fully, however the part I can read states it's a case of Beta testing & Beta software, so yes I'm all for it, so will send another E Mail off to Gap. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
H16UUP
