Home > Technical > What Diesel?
AndyLandy
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
What Diesel?
Hi all,
New bloke here
I have a very simple and silly question. Mr. Green
TDV6, do I just use non supermarket ordinary diesel?
Thanks in advance,
Andylandy
Post #403827 Wed Nov 27 2013 6:47am
Disco_Mikey
I fill up with Tesco finest diesel, purely down to convenience. A bit lumpy on very cold starts, but otherwise runs fine, and still returns 30+ mpg on a run Thumbs Up
Post #403828 Wed Nov 27 2013 7:00am
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Shell V power for me,a bit more expensive but I get 5mpg more with it ,the car runs better.Pays for itself and some Thumbs Up
Post #403830 Wed Nov 27 2013 7:09am
Shell Nitro+ for my motor, Ive been putting it in from new, and Ive never put anything else in. Not sure if i get anymore mpg, but i don't really care. Currently getting 27 mpg on a 18 mile daily round trip, all B roads.
Post #403833 Wed Nov 27 2013 7:48am
drdelrrs
Generally use supermarket fuel but every so often (5 or 6 fills) I give it a treat of the BP or Shell expensive stuff!
Post #403836 Wed Nov 27 2013 8:32am
SRE
Spain
BP ultra + 2T
MPG......not a lot, but I like the car Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #403839 Wed Nov 27 2013 8:39am
I used to use normal Esso diesel but for the last 12 months or so I've been using either Esso Supreme or BP Ultimate (I think those are the names). I doubt it gives any more performance really but I hope that the better cleaning additives will be better for the engine... Thumbs Up
Every now and then I give it a shot of Millers too. 2012 SDV6 - it's missing a couple of cylinders
Post #403850 Wed Nov 27 2013 9:26am
oxford-boy
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
If you google about cheap supermarket fuel you will find quite a lot about the lack of lubricants in cheaper fuel.
The advice is that every 4-5 tanks you should use a good quality fuel to ensure the fuel pump remains well lubricated.
Although it was some time ago I ran a diesel on cheap supermarket fuel for 15,000 miles and the fuel pump casing failed completely...it appeared via researching 'honest john' in the Daily Telegraph that it was very likely due to cheap non lubricant fuel.
The post about using a decent fuel every 5-6 tanks is probably right in my view.. 2005 Range Rover Sport TDV6 HSE in Artic Frost. 20" 2010 HST Alloys, sidesteps, Hawke tips, plus minor bits and bobs along with a remap. Four spike spiders ready for the Alps again now tucked up in their garage boxes...
Post #403853 Wed Nov 27 2013 9:59am
doing main in town driving using Tesco diesel i used to get 290 miles per tanks, when Shell opened a branch i swapped to using their Fuel Save Diesel and the occasional once or twice a month tank of Nitro + I now get 350 miles per tank and the engine doesn't rattle as much
Post #403854 Wed Nov 27 2013 10:05am
drdelrrs
If your car is fitted with a DPF it is not a god idea, in fact its a pretty bad idea, to add 2 Stroke.
Post #403856 Wed Nov 27 2013 10:24am
Paddi
The 2so debate will of course never end but I thought one of the proven benefits of adding 2so was less frequent cleaning of the DPF http://www.freel2.com/forum/topic878.html 2008 MY Java Black TDV8 HSE
Post #403859 Wed Nov 27 2013 11:00am
drdelrrs
^^^^ True its a subject around which there are a load of opinions.
My arguments are, even at high levels of dilution, ...
1. 2T oil is mainly designed for use in air cooled engines which run at higher surface temperatures than liquid cooled diesels so there will be increased residue on the relatively cool valves , pistons, and piston rings etc.
2. The 2T oil will not be fully burnt off - put your finger in the tail pipe of a 2T lawn mower or motorcycle (not while its running) and see the sticky sooty goo! This will be caught by your DPF and may not be burnt off by the regeneration cycle which is frequent of the Sport being scheduled about every other tank full in normal use.
3. Any fuel pumps, pipework or engine component failure etc. that you may want a contribution from LR / warranty policy will, if tested, reveal the 2T and so the 'contribution' will evaporate.
4. A turbo charger repair is likely to be £3k plus and the 2T is likely to be evident !!
Post #403860 Wed Nov 27 2013 11:41am
Stuart
Thanks for posting that link Paddi, there is some really interesting arguments put forward by the German chap there. I have a couple of gallons of two stroke oil in the garage sitting about as it happens......
I am also a supermarket fuel user. It never seemed to do our Sprinter vans any harm, but then again nor did the myriad of other substances we used to put in them masquerading as fuel back when times were hard.
Post #403861 Wed Nov 27 2013 11:52am
Dhups
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
I've used Shell V power nitro since ive had the car.
Again not sure if it gives any extra mpg but hopefully it looks after the engine better.
Post #403862 Wed Nov 27 2013 11:55am
Paddi
Stuart wrote:
Thanks for posting that link Paddi, there is some really interesting arguments put forward by the German chap others
I think 'Yamaha fan' is in fact.... A GIRL!
But I'm definitely not getting drawn into the 2so debate as there are more than enough posts on numerous websites if anyone wants to read up on the subject. The case for using premium fuels though is proven IMHO so would definitely support it. My TDV8 certainly likes Shell V power nitro stuff and runs more quietly. 2008 MY Java Black TDV8 HSE
Post #403872 Wed Nov 27 2013 12:55pm
