Home > General (L494) > Engine oil level not available
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
I've tried to check on oil level via the menu, but it keeps showing 'engine oil level not available'. Now, I know you have to wait 10 mins for the oil level to stabilise, which I've done a few times now....and also park on level ground! But the message still is the same. Previous D4 showed the oil level no problem, even at cold.
Also, still can't discover whether on the Autobiography, the menu should show timed climate and rest heat, as remote climate is an extra on the specs! But, on my Ab these functions are absent.
I've called the dealer service dept (Hunters Chester..are you listening?) twice today, who haven't called back...but buying at £77k car seems to mean very little ref after sales! I'd rather forgo the bottle of champagne they gave me on collection and have someone call back!
Post #403608 Mon Nov 25 2013 8:01pm
Idea Bob, i don't know if this will work on the RRS2 but it does on the original Laughing RRS. Try lifting the bonnet, then see if the oil level check is available. Hope this helps. Thumbs Up
Post #403616 Mon Nov 25 2013 8:30pm
peanutbob
No, I've decided to put a long straw in the filler cap instead...that should do the trick! Give or take a few litres here and there!
Post #403619 Mon Nov 25 2013 8:35pm
East Coast Sport
Scotland 2013 Range Rover Sport SDV6 HSE Orkney Grey
On mine the ignition has to be switched on, but the engine has to be stopped. It doesn't work with engine running. Its worth a try. 2017 3.0 SDV6 Autobiography Santorini Black
2015 3.0 SDV6 HSE Dynamic Indus Silver.
2013 3.0 SDV6 HSE Black Edition, Orkney Grey, 5 Spoke Diamond Turned Alloys, Ebony Premium Oxford Leather, Privacy Glass
Post #403676 Tue Nov 26 2013 8:32am
mse
Also needs to be warm but 10 minutes or something like that, after the engine first ran.
The ground has to be level Mike
2014 Facelift Discovery
Post #403687 Tue Nov 26 2013 9:23am
peanutbob
Thanks...I've done all that..engine warm...turned off ignition, waited 10 mins...but it doesn't work!
There was a thread from the states on range rovers.net ref this problem, which I came across a few weeks ago, but I can't find it again!
Post #403688 Tue Nov 26 2013 9:34am
peanutbob
Checked the level at stone cold this morning, and it worked! Went out for a 10 minute drive, parked up and returned to vehicle 45 mins later and it came up with engine oil level not available. Car was in park mode.
So, looks like it needs a lot more than 10 mins for the gauge to work.
Post #403713 Tue Nov 26 2013 12:21pm
