Home > Faults & Fixes > Suspension fault.. replacement seal kit from landyair ? |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 |
First time I sign into RRSPORT.co.uk for a while and I end up with suspension fault, have I been jinxed??...
Sat Nov 16 2013 11:55am |
Decided to go down the refurbish route ordered and received the new seal and air dryer overhaul kit from Landyair, sent through very quickly... stripped down and replaced seals as per the online videos, noticed a better seal with kit so all looked promising, went to reinstall and found another problem
Sat Nov 23 2013 5:24pm |
cheet Member Since: 06 May 2013 Location: Nuneaton Posts: 6 |
Hi
Mon Nov 25 2013 6:01am |
Where was the air leak and what did you do to repair ? Why?.. Because i can....
Mon Nov 25 2013 4:58pm |
The air leak was on the connection where the small pipe from the compressor enters the air drying unit.
Mon Nov 25 2013 11:51pm |
We'll suspensions now all sorted, took it to the guys at RCV at East Peckham nr tonbridge who kindly replaced the compressor and repaired the damaged pipe work... Decided although the pump was refurbed it may only be a matter of time before it would need replacement..
Thu Nov 28 2013 9:58pm |
Monty, do you have the old compressor still? Bodsys Brake Bible
Thu Nov 28 2013 10:01pm |
sorry I forgot to ask for it back and the garage is well out of my way to go get it Why?.. Because i can....
Thu Nov 28 2013 10:12pm |
No problem, just a thought Bodsys Brake Bible
Thu Nov 28 2013 10:15pm |
I have sent an email to see if they are willing to ship it to me will let you know Why?.. Because i can....
Thu Nov 28 2013 10:17pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Bodsy - I have my old EAS compressor 16MY Estoril Blue SVR.............
Peachy, would be useful to have a play with it
Thu Nov 28 2013 10:22pm |
what about the compressor 16MY Estoril Blue SVR.............
Thu Nov 28 2013 10:24pm |
after spending 80 quid on the new seal and air dryer I hope I can get it back Why?.. Because i can....
Thu Nov 28 2013 10:25pm |
