Home > Technical > Multiple Warning Lights |
Have you replaced a brake light bulb lately Or have you got a brake light bulb that has failed I know this sounds daft, but you'd be surprised what faults a blown brake light bulb can cause to the sensitive wiring system on a sport. |
Thu Nov 14 2013 11:47am |
norman1979 Member Since: 24 Apr 2013 Location: London Posts: 21 |
Just checked the brake lights and they are fine. . I haven't replaced a bulb recently either. |
Thu Nov 14 2013 11:58am |
Do the faults clear if you switch the ignition off then back on again |
Thu Nov 14 2013 12:04pm |
The suspension lowered and air suspension indicator turn on after a few seconds of starting/driving.
Thu Nov 14 2013 12:13pm |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
Brake light switch. Sits above the brake pedal. Access through removing the lower panel. £18. I had the same issue. |
Thu Nov 14 2013 3:39pm |
Would the brake lights work as normal if the brake like switch has gone? |
Thu Nov 14 2013 3:47pm |
Yes. Well they did on mine. Have a close look at the switch because you can sometimes see the burn marks. It just gets old and gives up resulting in these lights coming on. |
Thu Nov 14 2013 8:13pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
+1 on the brake light switch. I had the same problem at the weekend. Sorted by replacing the switch and following Paddi's guide here http://www.rrsport.co.uk/forum/topic30757.html
Thu Nov 14 2013 10:03pm |
Thanks for the reply guys. I will have a go this weekend and let you know how I get on. |
Fri Nov 15 2013 10:28am |
Quick update. Changed the brake light switch and still no change. |
Sun Nov 17 2013 2:19pm |
Battery in tip top condition? Again a weak battery can cause some warnings to come up. Next step would be get it plugged and see what codes you have stored and take it from there. |
Sun Nov 17 2013 7:08pm |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 |
Could be something to do with the electrics related to the towhook.
Mon Nov 18 2013 7:43am |
Okay guys. The car is in with a specialist.
Tue Nov 19 2013 2:08pm |
