Home > Technical > Multiple Warning Lights
norman1979
I'm currently experiencing some issues with my MY05 RRS. It starts and drives normally but the following lights are on the dash
Brake Light (Yellow exclamation mark)
Traction Light
HDC Not Active
Suspension Lowered
Air Suspension indicator
Anybody have any ideas?
Post #402042 Thu Nov 14 2013 11:20am
Have you replaced a brake light bulb lately Question Or have you got a brake light bulb that has failed Question I know this sounds daft, but you'd be surprised what faults a blown brake light bulb can cause to the sensitive wiring system on a sport.
Post #402045 Thu Nov 14 2013 11:47am
norman1979
Just checked the brake lights and they are fine. Sad. I haven't replaced a bulb recently either.
Post #402050 Thu Nov 14 2013 11:58am
Do the faults clear if you switch the ignition off then back on again Question
Post #402053 Thu Nov 14 2013 12:04pm
norman1979
The suspension lowered and air suspension indicator turn on after a few seconds of starting/driving.
The traction light, HDC not active and Brake light are on constantly Neutral
Post #402055 Thu Nov 14 2013 12:13pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Brake light switch. Sits above the brake pedal. Access through removing the lower panel. £18. I had the same issue.
Post #402091 Thu Nov 14 2013 3:39pm
norman1979
Would the brake lights work as normal if the brake like switch has gone?
Post #402092 Thu Nov 14 2013 3:47pm
SCdavies
Yes. Well they did on mine. Have a close look at the switch because you can sometimes see the burn marks. It just gets old and gives up resulting in these lights coming on.
Post #402126 Thu Nov 14 2013 8:13pm
RobP
+1 on the brake light switch. I had the same problem at the weekend. Sorted by replacing the switch and following Paddi's guide here http://www.rrsport.co.uk/forum/topic30757.html
The switch has two sets of contacts inside
1 for the brake lights and the other for the ECU. The ecu ones are what cause the issue, you brake lights work but the ecu doesn't
For £21 its the cheapest option after a blown brake light bulb and worth trying. There was nothing visibly wrong with mine from the outside but upon opening the old switch the blackened contacts and arcing mark were visible TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #402158 Thu Nov 14 2013 10:03pm
norman1979
Thanks for the reply guys. I will have a go this weekend and let you know how I get on.
Post #402208 Fri Nov 15 2013 10:28am
norman1979
Quick update. Changed the brake light switch and still no change. Sad
Post #402514 Sun Nov 17 2013 2:19pm
SCdavies
Battery in tip top condition? Again a weak battery can cause some warnings to come up. Next step would be get it plugged and see what codes you have stored and take it from there.
Post #402558 Sun Nov 17 2013 7:08pm
jochem00
Could be something to do with the electrics related to the towhook.
has a tow hook been supplied with your car or ever been used?
then there should be additional electronics installed in your car which could well be the cause.
Post #402641 Mon Nov 18 2013 7:43am
norman1979
Okay guys. The car is in with a specialist.
The battery is in the accepted voltage so I can rule that out. The vehicle has no towhook and was never supplied with one.
The specialist has advised that it is an injector fault causing these issues. Just looked at the price of injectors and almost fell over Crying or Very sad
I have googled injector faults for the RRS but I dont think anybody has experienced the same faults as I am. Hence me being slightly concerned Sad
Post #402804 Tue Nov 19 2013 2:08pm
