Home > Maintenance & Modifications > 7 year service SC |
RRS Daz Member Since: 22 Jan 2012 Location: Yorkshire Posts: 797 |
You forgot the tube of ky jelly. |
Thu Nov 14 2013 1:48pm |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 |
Thu Nov 14 2013 3:20pm |
You can see the service item list in the sticky at the top of this section: http://www.rrsport.co.uk/gallery/albums/us...0Miles.pdf But you are just trying to tempt me into another rant about 'oil flush' aren't you? I don't want to repeat myself so just consult #snake oil, #rip-off, #robbin bast s Be interesting to insist they show you documentary evidence that Land Rover recommend oil flush before you will authorise it I wonder how many engine failures pouring this rubbish into the sump causes every year. 2008 MY Java Black TDV8 HSE |
Thu Nov 14 2013 4:01pm |
LOCUST Member Since: 02 Oct 2013 Location: ESSEX Posts: 75 |
after a few phone calls i have got it down to �440 at a reccomended independant.... |
Thu Nov 14 2013 5:51pm |
Apart from normal engine oil, filters etc. I assume you�ve done or will do all these as well !!
Thu Nov 14 2013 6:50pm |
Seriously?....... Anyone had that done? and the OP won't need timing belt changed as he has a TDV8 which doesn't have a belt. 2008 MY Java Black TDV8 HSE |
Fri Nov 15 2013 4:42pm |
You're right Paddi - I just pulled the info off the Workshop manual |
Fri Nov 15 2013 8:39pm |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
Mine is seven years old. It cost three and a bit including anti roll bar bushes and an aircon re-gas at Landranger (not with cam belts but mobile guys here do that for circa �275).
Fri Nov 15 2013 9:06pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
Hello
Sat Nov 16 2013 10:05am |
Whizzee111s Member Since: 17 Sep 2011 Location: Basildon Posts: 53 |
Where a outs in Essex are you? Taking my s/c to ongar bridge to have the supercharger cooling pump as it putting the car into limp mode. Mines a 55 plate with80k on the clock which according to its service book is due for a 'B' service Freelander SE - Gone
Mon Nov 18 2013 9:37pm |
Im in harlow mate, there is an inde called broadfields and the guy lives in harlow so can take it in for me, they come highly reccomended |
Tue Nov 19 2013 2:11pm |
