![]() | Home > Maintenance & Modifications > RRS 2005 Battery....Please help!!!!! |
skilachi Member Since: 31 Oct 2013 Location: London Posts: 55 ![]() |
If you can get access to a C-Tek charger you could try the battery on a reconditioned charge to see if that brings it back, but if you have an ordinary charger it would take a couple of days charge to charge it up fully, just running the car for 5 or 10 mins does not do anything to the battery if its flat you would need a good few hours driving to charge it up.
Probably be worth getting the £70 battery. 2012 SDV6 - it's missing a couple of cylinders
Not too sure about the 2005 cars but certainly the later ones have a charge control unit that adjusts alternator output voltages for different temperatures and thus battery charging rates. Consequently making sure the battery you fit is fully compatible with the OE spec is important as there is a suggestion that incompatibility can lead to premature alternator failure.
Thanks, exactly what I'm trying to avoid by getting under or over spec model.
For what its worth the bit in the workshop manual I remembered says ....
drdelrrs, thanks for your comment but must admit have no clue what about all the technical details but do get what you are trying to say. so in short there is a mechanism which sort of step up/step down voltage depending on temp and also sends a warning signal/faults to CAN bus.
Hi Skilachi
