Home > Technical > Surge at idle
DRanged
2006 Range Rover Sport TDV6 HSE Java Black
Surge at idle
Since having my 7 year service I've noticed a slight surging/ hunting in the revs at idle. Only happens every now and again.
Has anyone any ideas before I go back to LR to moan?
It's a 2.7tdv6 with 25k
Thanks.
Post #401882 Tue Nov 12 2013 10:28pm
Rsdave137
England 2007 Range Rover Sport TDV6 HSE Java Black
Hi, did you have timing and fuel pump belts replaced
Post #401883 Tue Nov 12 2013 10:32pm
DRanged
Certainly did, it was due by age.
Post #401885 Tue Nov 12 2013 10:45pm
Rsdave137
Hi, sounds as if fuel pump timing half tooth out
Post #401887 Tue Nov 12 2013 11:24pm
Disco_Mikey
Fuel pump timing cannot be half a tooth out.
It is a common rail system, and the pump is only there to provide pressure to the fuel rails. It is not timed to the engine at all, that is controlled by the injectors/PCM Thumbs Up
Post #401892 Wed Nov 13 2013 6:50am
DRanged
Yeah the fuel pump timing isn't important.
I was thinking of a poor manifold seal or dodgy egr?
Anyone agree?
Post #401893 Wed Nov 13 2013 7:51am
DRanged
N/s egr sticking.
Time for a blanking kit.
Post #402046 Thu Nov 14 2013 11:48am
