Home > Technical > Black Vue Camera
Jonny Fresh
I got mine professionally fitted, all in £300. Excellent product and excellent installation job
Post #401819 Tue Nov 12 2013 2:29pm
fitted mine myself, excellent installation and only £212.79 including power magic, bought on disco3 group buy
only been replaced the once due to freezing and not recording and now sending back the power magic as that turns itself off all the time, even when the car is on charge, so its either fault volt meter or timer
Post #401820 Tue Nov 12 2013 2:33pm
muddywheels
Milk Float Man
My powersaver shuts down BV when heated seats and/or FBH on. Also had problems with BV crashing and had to restart - now have to check all lights are normal before driving off to be sure Sad
Just upgraded firmware and keeps telling me the version information is different Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #401821 Tue Nov 12 2013 2:39pm
Jonny Fresh
Laughing Laughing Laughing how modest
Post #401823 Tue Nov 12 2013 2:55pm
muddywheels
Milk Float Man
He means he had no broken clips and scratched panels like he would have from LR trained technicians Whistle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #401825 Tue Nov 12 2013 3:00pm
Mr. Green
i must admit the excellent installation was done and the 4 revisits to swap the fuse i was piggy backing off were not mentioned, i looked and found the "right fuse" only to be told it switched off after X time, did that 3 times
should have done my homework first, 5 minutes searching would have saved that
Post #401835 Tue Nov 12 2013 3:39pm
fkarim
I bought BV 500 + Power Magic + 2 holders + 2 power leads for £229.99 in July from Ian's private sale on Disco 3 (user hids4u). Excellent service Thumbs Up
Followed MW's DIY guide. No issues so far since I eventually successfully installed it. The only niggle is it doesn't seem to remember that it is configured not to record audio. I have to manually switch off audio recording everytime it restarts following power saver shutdown.
Post #401860 Tue Nov 12 2013 6:15pm
PEACHY
fkarim - are you saving the settings after you have changed them on the SD card . Thumbs Up 16MY Estoril Blue SVR.............
Post #401862 Tue Nov 12 2013 6:32pm
fkarim
Yes Peachy. Saving and then restarting the camera as the manual says. It remembers all other settings. Even the audio recording setting says "off" but it still records it. Upgrading firmware didn't help either Banging Head
At least turning it of manually is just a matter of waving finger close to the sensor.
Post #401864 Tue Nov 12 2013 6:47pm
CrustyJuggler
i had this too on the 500, but found that "quickly" pressing the sensor to next to the wifi light on the end overrode (not sure thats a word but it'll do) the other settings.
Post #401895 Wed Nov 13 2013 8:11am
Kenzi
Australia
What's the general consensus then.. Are these worth while?
Post #401898 Wed Nov 13 2013 8:37am
muddywheels
Milk Float Man
I bought mine as they were highly recommended on disco and here but not having used any others not sure if they are the best. Certainly better than none at all Sad Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #401899 Wed Nov 13 2013 8:52am
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Can be apita when they don't work Big Cry
Post #401900 Wed Nov 13 2013 8:54am
