Home > Technical > Suspension issue I think
tizifred
Hi guys. I have a problem I hope you can help with.
I have 2006 RRS with DR. I think it's leaning to the left but not 100% sure on this. When you look at the screen it says it's level.
However when I go round a right had bend ie a roundabout or even a right hand curve the traction control comes on. It's fine on left hand corners.
All tyre pressures are correct.
To be honest it's getting to be a pig to drive.
Any ideas guys
Post #401788 Tue Nov 12 2013 9:48am
Tricky. Have you had a proper 4-wheel alignment check carried out? If not, it would be a good start. Make sure they put it in tight tolerance mode beforehand (and back to normal afterwards).
If that comes back as satisfactory, then you might be looking at a steering wheel angle sensor issue. You could ask a local LR or indy to check and calibrate it for you.
Alternatively, could be the yaw sensor or a wheel speed (ABS) sensor issue.
I'd start with alignment and steering angle sensor.
Whilst they've got it on the lift to do the alignment, it wouldn't hurt to check that there are no wires chaffing (thinking maybe a front ABS wire). 2012 SDV6 - it's missing a couple of cylinders
Post #401824 Tue Nov 12 2013 3:00pm
tizifred
Thanks mate
I did see another similar post after I posted this one. I read that one and it says about the four wheel alignment.
I'm just trying to get hold of a mate now to see if he can do it
Thanks again
I'm sure I'll need help again
Post #401828 Tue Nov 12 2013 3:06pm
