Home > Technical > Whistle and Misfiring. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
The usual advice at this stage is to check the intercooler hoses for splits or other damage. They are the two big ones right at the top/front of the engine bay looking like radiator hoses. They are a relatively cheap item to replace if they do show any damage. 2012 SDV6 - it's missing a couple of cylinders
Wed Oct 30 2013 11:32am |
As has been said - check the hoses associated with the turbos; there are two more short 'L' shaped ones under the engine acoustic cover (my local LR dealer says these short ones are a common issue but I've never seen a post about them on this forum!).
Wed Oct 30 2013 12:32pm |
07RRSTDV8 Member Since: 30 Oct 2013 Location: south east Posts: 13 |
Ok I'll try that first, are you suggesting those for the whistling noise or the misfiring? Or a combo of both? |
Wed Oct 30 2013 3:08pm |
Whistling noise particularly. Maybe if there is a big enough leak it could cause a misfire but TBH I don't know. Usually people report black exhaust smoke on acceleration and some loss of power when a hose is leaking. 2008 MY Java Black TDV8 HSE |
Wed Oct 30 2013 3:27pm |
Ok thanks for the help. My garage is waiting on a two post ramp to be installed, but looks like it could be two more weeks before its fitted and he can lift the body. I know it's possible to remove the pass side head off with the body still on.
Fri Nov 08 2013 10:24am |
Sorry but I don't know the answer to that question. Hopefully someone who does know might be along soon to advise you. 2008 MY Java Black TDV8 HSE
Fri Nov 08 2013 11:09am |
Anyone know if drivers side head can be removed with body on? |
Sun Nov 10 2013 9:48pm |
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 |
body off is an easy job
Sun Nov 10 2013 10:29pm |
