Home > In Car Electronics > how do i check if my rrs has bluetooth or phone conections
dondon1
England 2007 Range Rover Sport TDV6 SE Santorini Black
how do i check if my rrs has bluetooth or phone conections its a 2007 se tdv6 it hasnt got the satnv screen in it it only has the radio 6 disk but all the functions are there on the steering wheel and on the stereo how do i check to see if every ting is there so i can connect my phone
Post #401386 Thu Nov 07 2013 9:16pm
Bodsy
Site Sponsor
Do you have the red and green phone buttons on the steering wheel? If not, then you don't have phone. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #401391 Thu Nov 07 2013 9:19pm
dondon1
yes the red and green buttins are on the steering wheel
Post #401393 Thu Nov 07 2013 9:23pm
Bodsy
Site Sponsor
Then you should search for devices and it may come up with Handsfree or Landrover or possibly even ford
Then the pairing code should be 2121 if it was factory fit, or 1234 or 0000 if it was the dealer fitted version Bodsys Brake Bible
See it HERE
Post #401396 Thu Nov 07 2013 9:38pm
dondon1
it say no phone fitted what would i need to do it and were would i check to see if the stuff is in the jeep
Post #401401 Thu Nov 07 2013 10:07pm
Bodsy
Site Sponsor
Try jeep.....? Jeep!!!
That there's hanging talk boy..... Wink
On your phone, you need to go to Bluetooth and search make sure the ignition is on. It should find it, or someone's put a replacement wheel on that had the buttons on already..... Bodsys Brake Bible
See it HERE
Post #401403 Thu Nov 07 2013 10:18pm
dondon1
when i click the fone buttons it say on the stereo no fone fitted so that does mean that the wheel is wired up to the stereoand it hasnt had a wheel changed
Post #401406 Thu Nov 07 2013 10:24pm
Bodsy
Site Sponsor
You need to connect the BT on your phone otherwise it will only ever say no phone fitted. Bodsys Brake Bible
See it HERE
Post #401409 Thu Nov 07 2013 10:38pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
@dondon 1
On Your phone (the handheld, not the cars), go into "settings" and activate bluetooth, and "search for devices"
On Your steeringwheel, toggle the green telephonebutton once.
You might get a message on Your dash that says "no phone fitted".
In Your telephone (handheld) You will se "Land Rover" select "connect to device" or similar.
The pairing code is 2121.
On dash You will get a message "Phone connected"
But if it is as You said: "it say no phone fitted what would i need to do it and were would i check to see if the stuff is in the jeep", You are in the wrong car, this is the instruction how to pair a telephone in a Land Rover /Range Rover.. (couldn´t help myself)
Hope that this will be of some help.
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #401448 Fri Nov 08 2013 12:44pm
dondon1
every thing is in the car the bluetooth box is in the back behind the little pull of thing and wen i unplug it the red light comes on on it but i just cant find any thing on my phone at all or my wifes phone so is there any thing else i could do?
wen i press the green phone switch on the steering wheel it says on the stereo (no phone conected) and ive searched lots of times on my phone wot else could you advise me on please
Post #401478 Fri Nov 08 2013 5:44pm
BKHK
I think that your Jeep has no BT phone system. You will have to go to Jeep and buy an aftermarket system which, if you want it through the stereo, will need to be fitted by a Jeep dealer. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #401515 Fri Nov 08 2013 10:32pm
Stephen J
Netherlands 2005 Range Rover Sport Supercharged Java Black
Check your phone´s manual on how to connect to BT devices, then proceed as explained above.
Post #401561 Sat Nov 09 2013 3:19pm
