Home > In Car Electronics > how do i check if my rrs has bluetooth or phone conections |
Do you have the red and green phone buttons on the steering wheel? If not, then you don't have phone. Bodsys Brake Bible
Thu Nov 07 2013 9:19pm |
dondon1 Member Since: 22 Oct 2013 Location: hartlepool Posts: 15 |
yes the red and green buttins are on the steering wheel |
Thu Nov 07 2013 9:23pm |
Then you should search for devices and it may come up with Handsfree or Landrover or possibly even ford
Thu Nov 07 2013 9:38pm |
it say no phone fitted what would i need to do it and were would i check to see if the stuff is in the jeep |
Thu Nov 07 2013 10:07pm |
Try jeep.....? Jeep!!!
Thu Nov 07 2013 10:18pm |
when i click the fone buttons it say on the stereo no fone fitted so that does mean that the wheel is wired up to the stereoand it hasnt had a wheel changed |
Thu Nov 07 2013 10:24pm |
You need to connect the BT on your phone otherwise it will only ever say no phone fitted. Bodsys Brake Bible
Thu Nov 07 2013 10:38pm |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
@dondon 1
Fri Nov 08 2013 12:44pm |
every thing is in the car the bluetooth box is in the back behind the little pull of thing and wen i unplug it the red light comes on on it but i just cant find any thing on my phone at all or my wifes phone so is there any thing else i could do?
Fri Nov 08 2013 5:44pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1940 |
I think that your Jeep has no BT phone system. You will have to go to Jeep and buy an aftermarket system which, if you want it through the stereo, will need to be fitted by a Jeep dealer. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Fri Nov 08 2013 10:32pm |
Stephen J Member Since: 28 Oct 2013 Location: Amsterdam Posts: 16 |
Check your phone´s manual on how to connect to BT devices, then proceed as explained above. |
Sat Nov 09 2013 3:19pm |
