Home > Technical > possible air suspension issue |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
More likely to be a valve issue in one of the valve blocks. There are three valve blocks: one for each end of the vehicle and one adjacent to the compressor. 2012 SDV6 - it's missing a couple of cylinders
Tue Oct 22 2013 8:21pm |
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 |
is there anyway to check them? |
Tue Oct 22 2013 11:24pm |
There are fault codes associated with the valve blocks so you could have the codes read by an LR dealer or a good independent specialist which would probably be less expensive. 2008 MY Java Black TDV8 HSE
Wed Oct 23 2013 12:12am |
I think you'll need a diagnostic tool of some kind.
Wed Oct 23 2013 12:20am |
will try this as it seems cheapest |
Wed Oct 23 2013 6:16pm |
