![]() | Home > Technical > Problem with air suspension not falling out of extended mode |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Is it the AMK compressor, if so mine does the same - doesn't always lower first time & gives the same message and I think it is noisier than the previous one but it seems to work well - only time will tell if the AMK is better |
B3EEE Member Since: 20 Apr 2012 Location: Wales Posts: 450 ![]() ![]() ![]() |
not sure of make, it came via LR main dealer. Even though it may be better long term, it shouldn't be making louder noises or giving this error ? |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 ![]() ![]() ![]() |
It does sound a bit odd! I hope someone comes along to advise you if the dealer is mugging you off or not! MY2007 RRS TDV8 Black - tinted glass - side steps- stormer grille - 20" diamond cut alloys - alpaca leather - TV/DVD pack - some blingy chrome bits & bob's |
Something not right there. When the suspension is operating normally you can only select three heights: access height, on-road height or off-road height.
I think I may have used extended mode instead of off-road mode, but i'll check what the dash states first |
The AMK compressor is slightly louder than the old one but the difference shouldn't be too much. www.rrsport.co.uk/forum/topic31004.html |
Just spotted this in the manual which could be important for the OP:
