![]() | Home > General > Swaying problem |
dal1557 Member Since: 30 Jun 2013 Location: Montrose Posts: 23 ![]() ![]() ![]() |
Hi
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 ![]() ![]() ![]() |
Sounds the same as mine skittish back end and the odd clunk coming off islands
Paszko Member Since: 27 Jun 2011 Location: Halifax Posts: 18 ![]() ![]() |
Dal1557 did you manage to get to the bottom of this?
ive had all my bushes changed front and back runs perfect now
Do u know if it was the top or bottom ones, or both you had changed. |
The usual failures are the front lower wishbones and the rear upper wishbones. |
Bodsey thanks for that, my mechanic suggested that it could be the rear upper ones. had the lower front ones done about 6 month ago, so looks like im ordering the rear ones also. |
