Home > General > Swaying problem
dal1557
Swaying problem
Hi
When am dring on the motor way my Rrs drives great but if I hit a bump on the road the back end sways about the road quite bad can anyone help me identify the problem ??? D Ledingham
Post #387432 Sun Jun 30 2013 6:12pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Re: Swaying problem
Your suspensions fooked Shocked
Book her in Thumbs Up
Nik
dal1557 wrote:
Hi
 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #387438 Sun Jun 30 2013 9:14pm
dal1557
Hi
Was kinda hoping someone could identify the problem so I know what parts to get? D Ledingham
Post #387439 Sun Jun 30 2013 9:26pm
Nik
I'd be surprised if anyone can identify your problem over the net in order for you to order parts.
Nik.
dal1557 wrote:
Hi
 2015 Golf R DSG
Post #387441 Sun Jun 30 2013 9:53pm
dal1557
Maybe someone will have had the same problem and knows the oats needed D Ledingham
Post #387443 Sun Jun 30 2013 9:57pm
simple1
I will hazard a guess, rear wishbone bushes. If your doing them, you need to replace the lot, 4 each side. And replace all the bolts and captive nuts as will bet you will have to cut at least two. Thumbs Up and don't forget a full four wheel aligment after Bow down
Next in the telepathy que please Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #387451 Sun Jun 30 2013 10:56pm
drdelrrs
You've probably checked tyre pressures ! Thumbs Up
Post #387492 Mon Jul 01 2013 1:06pm
Paddi
Have a look underneath? Anti-roll bar drop link(s) come adrift/broken or bushes cream crackered? 2008 MY Java Black TDV8 HSE
Post #387497 Mon Jul 01 2013 1:54pm
dal1557
Just had my Rrs in garage today and no faults were found with any of the bushes atall tyre pressure was at 40 gArage recommended put tyre pressure to 45 ???
What's the best tyre pressure to put them at? D Ledingham
Post #387565 Tue Jul 02 2013 11:27am
simple1
With 20" wheels I ran 42 rear and 36 front. Had 100% even tyre wear. Pumped rears up to 46 when towing. Can say the tyre pressures being a little off would cause rear to sway at speed. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #387577 Tue Jul 02 2013 2:28pm
4 wheel alignment then Thumbs Up RRS gone
Post #387578 Tue Jul 02 2013 2:35pm
Paddi
Is this a new problem or has it just developed?
What brand are the tyres and are they the correct specification? Thinking perhaps the load rating is not correct?
If you post up the spec written on the sidewalls - the tyre gurus can advise 2008 MY Java Black TDV8 HSE
Post #387604 Tue Jul 02 2013 5:33pm
dal1557
Hi there my tyre sizes are
285/35/r22. 106wxl D Ledingham
Post #387605 Tue Jul 02 2013 5:47pm
dal1557
The sway just ain't at speed it will do it in town at 30 mph only when I hit a bump but not every bump will do it , it's only when one wheel goes in a pot hole or something like that
Yip it's a strange on eh 😳 D Ledingham
Post #387607 Tue Jul 02 2013 5:51pm
simple1
Sway= movement in back end. Simples. Tyres will not affect the car at low speed even with 22 wheels. Might make the ride a bit more uncomfortable. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #387615 Tue Jul 02 2013 7:01pm
