Home > General > FUZE for trailer/caravan problem |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
Does your caravan not have a selector switch? To use the onboard caravan battery or car battery? |
Fri Oct 11 2013 6:58am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
You have a fault somewhere in your charging system for caravan or white plug. There is a relay that prevents power going to caravan unless there is over 13 volts in car system ie when it's running. If you run your fridge on gas, you will greatly reduce the drain if you have to leave the connected over night. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Oct 11 2013 7:11am |
Why are you leaving it connected over night |
Fri Oct 11 2013 7:54am |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
There is a permanent (not relay switched) feed to the tow electrics - removing the fuse could help you track down the issue but you should fix the reason for the drain rather than use that as a permanent solution Like this site? Buy some RRSPORT goodies to show your support! |
Fri Oct 11 2013 8:49am |
There are both a permanent and switched 12V supply. Like this site? Buy some RRSPORT goodies to show your support! |
Fri Oct 11 2013 2:28pm |
Cupra Member Since: 20 Oct 2012 Location: Kent Posts: 81 |
depending what you have fitted most systems should switch off the fridge and 12v feed with the ignition, ive a smartcom fitted to mine and ive never had a problem |
Sat Oct 19 2013 8:26pm |
