Home > General > engine system falult
M55RK H
Hi, Guys wonder if you can help driving home to night noticed on the display it said engine system fault went into slow mode then just died,, wont even start up , engine turns over ok but thats it MARK
Post #397703 Tue Oct 08 2013 8:21pm
adigorn
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
run out of fuel due faulty sensor Question
Post #397737 Tue Oct 08 2013 11:30pm
More likely that the fuel sensor was saying "empty" when the tank still has fuel in it. This happened to a friend's RRS. Left him sat on the side of the road as the thing refused to believe it had any fuel in it... 2012 SDV6 - it's missing a couple of cylinders
Post #397738 Tue Oct 08 2013 11:53pm
simple1
Or it's done what mine did and digested the turbo deals Big Cry 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #397824 Wed Oct 09 2013 7:03pm
M55RK H
fault codes
hi guys the fault code is p0087 p140a and 0100 any one know these MARK
Post #397833 Wed Oct 09 2013 7:40pm
P0087
Fuel rail/system pressure – too low
P140A
Exhaust gas recirculation sensor C – circuit low
The last one is missing a letter so:
U0100
Lost communication with engine control module/powertrain control module ‘A’
P0100
Mass or volume air flow circuit 2012 SDV6 - it's missing a couple of cylinders
Post #397841 Wed Oct 09 2013 8:31pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Could it be a problem with one of the injectors, leak off leading to low pressure? I had this on a FF Rangie just wouldn't start!
Post #397887 Thu Oct 10 2013 10:18am
DK3000AR
United Kingdom 2007 Range Rover Sport TDV6 SE Java Black
I too have been suffering from the all-systems errors for months now. To date, have changed EGR valves, new battery, new air, oil and fuel filters, replaced brake bulbs, and replaced brake light switch.
Today I decided to blank the EGR valves and as I had to replace a failed water outlet connection I had to pull the throttle body off. This is what I found, and I think a perfect example of why EGRs should be banned:
The throttle body:
And the air manifold:
I have never seen so much crud and c*** in an air manifold. I was utterly shocked. As a genuine user of a Range Rover for its offroad ability (living in darkest west Africa) I cannot believe that a design could cause such a potentially catastrophic event.
A good soak of the throttle body in petrol and a good go with a modified vacuum cleaner - I was able to clean out at least some of this awful gunk.
Reassembled everything (with my new EGRs now firmly blanked) and have just done a test run. The car is certainly running much better, has noticeably better pickup and acceleration.
HOWEVER, when putting my foot to the floor I still recreate the all-system error (Tranmission fault, HDC fault, Suspension lowered, F on the dash)! As always, stop turn off the engine and restart and everything is back to normal.
The fault code is as ever "P0087 - Fuel rail / system pressure - too low" (as read from my awesome IID Bluetooth tool).
Tomorrow I will change the fuel filter again... but beyond that I cannot think what else to do. Anyone got any clues?
Post #398968 Fri Oct 18 2013 9:38pm
Disco_Mikey
In tank pick up filter blocked Thumbs Up
Very common if fuel system is not immaculate.
Post #398977 Fri Oct 18 2013 10:18pm
DK3000AR
Mikey - always a doyen of knowledge on these matters!
Don't suppose you've done a How To on that have you? If not but could give me some pointers then I'll gladly tackle that tomorrow with camera in-hand a post it a la your How-to's.
BTW - bought a decat pipe last week but no room to bring it back with me from UK as I had to bring a 6' tall stuffed toy for my daughter! Hopefully will get that posted in the couple of weeks too.
Post #398980 Fri Oct 18 2013 10:26pm
Disco_Mikey
Not done a How-To for fuel tank removal. Run out of space in my sig for adding all of them as it is Laughing
Not a difficult job. Tank is held in with 6 bolts IIRC. Fuel pipes need disconnected at the front, filler pipes/breathers at the rear of the tank, and lower the tank enough, to get into the wiring. Once off, drop the tank right down Thumbs Up
Post #399002 Sat Oct 19 2013 8:51am
DK3000AR
Today I had the fuel tank off to give the in-tank fuel filter a good clean. As you can see - they were not pretty and you can even see shiny bits of metal in the swirl pot suggesting that something ain't right in there:
So convinced was I that this was going to be the root of all my problems I gave the filters a good clean and put it back together again:
Sadly, any good mechanic would have actually checked that the pump was working properly before re-assembling and maybe it was the 34º heat and blazing sunshine that got the better of me... but I didn't.
Voila, the pump isn't running and so the fuel tank will have to come off and be taken apart again tomorrow. Big Cry
The only slightly positive note is that being in a former French colony I'll probably find a pump for a Peugeot 605 for a decent price as it is the same as the one that LR charge nearly £500 for in the UK.
Post #399181 Sun Oct 20 2013 7:30pm
DK3000AR
Incidentally, now that I think back I reckon that this pump has been kaput for a while as last time I replaced the fuel filter the garage used a vacuum pump on the fuel bleed valve in the engine bay to get her going. And I don't actually remember hearing the fuel pump at any point (it's usually quite noticeable I believe??).
If this is the case then I find it amazing that the vehicle can still work (albeit with much lower performance) by relying solely on the high pressure pump sucking fuel from the tank to the engine...
Post #399182 Sun Oct 20 2013 7:33pm
M55RK H
All fixed now guy,s thankyou it was the fuel pump in the tank, hadit replaced, running sweet now Thumbs Up MARK
Post #399266 Mon Oct 21 2013 1:00pm
