![]() | Home > General > engine system falult |
M55RK H Member Since: 20 Feb 2010 Location: STOKE-ON-TRENT Posts: 35 ![]() ![]() ![]() |
Hi, Guys wonder if you can help driving home to night noticed on the display it said engine system fault went into slow mode then just died,, wont even start up , engine turns over ok but thats it MARK |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
run out of fuel due faulty sensor |
Or it's done what mine did and digested the turbo deals |
hi guys the fault code is p0087 p140a and 0100 any one know these MARK |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
P0087
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
Could it be a problem with one of the injectors, leak off leading to low pressure? I had this on a FF Rangie just wouldn't start! |
DK3000AR Member Since: 19 Sep 2013 Location: Dakar Posts: 18 ![]() ![]() ![]() |
I too have been suffering from the all-systems errors for months now. To date, have changed EGR valves, new battery, new air, oil and fuel filters, replaced brake bulbs, and replaced brake light switch.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4450 ![]() ![]() ![]() |
In tank pick up filter blocked |
Mikey - always a doyen of knowledge on these matters!
Not done a How-To for fuel tank removal. Run out of space in my sig for adding all of them as it is |
Today I had the fuel tank off to give the in-tank fuel filter a good clean. As you can see - they were not pretty and you can even see shiny bits of metal in the swirl pot suggesting that something ain't right in there:
Incidentally, now that I think back I reckon that this pump has been kaput for a while as last time I replaced the fuel filter the garage used a vacuum pump on the fuel bleed valve in the engine bay to get her going. And I don't actually remember hearing the fuel pump at any point (it's usually quite noticeable I believe??).
All fixed now guy,s thankyou it was the fuel pump in the tank, hadit replaced, running sweet now |
