Home > Technical > Leaking Rear Anti Roll Bar |
Yes it's a common problem - but not usually quite that early. The ARC bar isn't protected by a boot so grit can get in and destroy the seals. Seems like another example of poor design considering this is supposed to be an off-road vehicle!
Tue Oct 01 2013 1:34pm |
hondagoneda Member Since: 06 Jun 2013 Location: Cheshire Posts: 22 |
Cheers Paddi - thanks for the technical appraisal. It’s useful and concerning at the same time. I hope this is not a sign that mine has had a “harder than usual off road life". Even though the car is supposed to be designed to take some stick..
Tue Oct 01 2013 2:06pm |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
Re comment above on need for a rubber boot on actuator.
Tue Oct 01 2013 9:39pm |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
That's not good to hear hondagoneda......sounds like the MY12 could be starting to exhibit the other traits of earlier RRS's
Wed Oct 02 2013 8:14am |
Mmmmm, I hope not
Wed Oct 02 2013 1:34pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
Mine started leaking at about 50k miles. Replaced under warranty. 2012 SDV6 - it's missing a couple of cylinders
Wed Oct 02 2013 4:14pm |
