Home > In Car Electronics > SAT NAV ISSUE
RRS Craig
United Kingdom 2010 Range Rover Sport TDV6 HSE Santorini Black
SAT NAV ISSUE
You may have read my other post re: Intermittent radio signal. This however is related to my sat nav as a local traffic announcement will come on either when listening to the radio or sat nav which is really anoying!!! Can anyone advice me how i can disable this, i have looked in settings with no luck.
Regards Craig RRS
Post #393739 Wed Sep 04 2013 10:58am
Assuming you have a facelift MY2010 as per your signature?
If so, from your handbook (page 289) Whistle Thumbs Up
TRAFFIC INFORMATION
Selecting traffic information
Briefly press the INFO hard key, the TA
indicator appears on the right of the display.
When a radio station capable of providing
traffic information is selected, the TP indicator
appears alongside.
If a traffic announcement is received, the
current audio source will be interrupted by the
information broadcast.
The station name and TRAFFIC will alternately
appear in the display. At the end of the
broadcast, the previously selected audio
source will resume.
Cancelling an announcement
To cancel an announcement briefly press the
INFO hard key.
Switching off traffic information
Briefly press the INFO hard key (the TA
indicator will disappear from the left side of the
display). This action will prevent traffic
information broadcasts from being received
until the feature is reselected.
Tuning difficulties
• If the radio is tuned to a weak FM signal (in
remote areas, for example) or a radio
station that cannot provide traffic
information, when the INFO hard key is
pressed, the tuner will search for a good
traffic information signal. TP SEEK will be
displayed for the duration of the search.
• If a traffic information station cannot be
found, the words Not Found will be
displayed. In this case the radio will return
to the previously tuned frequency.
• If the signal from a traffic information
station weakens, the TP indicator in the left
side of the display will start to flash. In this
case, press either of the Search controls to
start searching for another radio station. If
the traffic information signal weakens
during CD play, the radio will automatically
attempt to locate and re tune to a traffic
information station with a stronger signal.
Note: If a non-traffic information station has
been stored on one of the pre-set soft keys, and
is selected while the traffic information facility
is switched on, the radio will remain on the
selected station unless Traffic Information is
turned off and on again. ON THE WAY: BMW F21 M140i
Post #393743 Wed Sep 04 2013 11:26am
RRS Craig
Sat Nav
Beancounter, i have just tried this and i hope it is as easy as just pressing the Info button until the TA indicator dissapers! job done...i hope RRS
Post #393750 Wed Sep 04 2013 11:57am
