Home > Maintenance & Modifications > air pump replacment
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
air pump replacment
changed my air pump today and i think its cured my problam Thumbs Up just driven over 100 miles and no lights on so result i think and an easy job to do aswell Thumbs Up
Post #393446 Sat Aug 31 2013 7:23pm
a13xbb
I take it you mean the suspension air compressor? How long did it take? didn't you have to update the software for the new pump?
Post #393451 Sat Aug 31 2013 8:32pm
cossiedave
took about 1.5 hours to do but i got held up when one off the air pipe was siezed in, just plugged it in and it works fine
Post #393452 Sat Aug 31 2013 9:15pm
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Software not always needed. Glad you sorted out with only one hoses issue.
Post #393483 Sun Sep 01 2013 6:18pm
cossiedave
cheers scdavies, read quite a bit on how to change pump before i did it and thought it looks a big job, there is only 3 10mm holding outer case on, when you take them out the bottom bit un clips from the top section then you can wiggle the top bit out , there are 2 torques on the top and one on the bottom that hold the motor in place, next unclip 2 wire connectors then take the 3 air pipes off them lift it out job done
Post #393485 Sun Sep 01 2013 6:48pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Did you replace it with a like for like one or the new style that has a slightly different bracket and comes with some new pipes?I put the new one on mine which made it even easier as you just cut the old pipes and fit supplied connectors.
Someone asked about software,I replaced the relay (you get one with the new pump)the supplier said the software didn't need renewing,I did however have an update put on but the car didn't like it so reverted back to the original software.
It's a half hour job. Thumbs Up
Post #393514 Mon Sep 02 2013 6:53am
