Home > Maintenance & Modifications > air pump replacment |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
changed my air pump today and i think its cured my problam just driven over 100 miles and no lights on so result i think and an easy job to do aswell |
Sat Aug 31 2013 7:23pm |
took about 1.5 hours to do but i got held up when one off the air pipe was siezed in, just plugged it in and it works fine |
Sat Aug 31 2013 9:15pm |
SCdavies Member Since: 28 Dec 2010 Location: south coast Posts: 324 |
Software not always needed. Glad you sorted out with only one hoses issue. |
Sun Sep 01 2013 6:18pm |
cheers scdavies, read quite a bit on how to change pump before i did it and thought it looks a big job, there is only 3 10mm holding outer case on, when you take them out the bottom bit un clips from the top section then you can wiggle the top bit out , there are 2 torques on the top and one on the bottom that hold the motor in place, next unclip 2 wire connectors then take the 3 air pipes off them lift it out job done |
Sun Sep 01 2013 6:48pm |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
Did you replace it with a like for like one or the new style that has a slightly different bracket and comes with some new pipes?I put the new one on mine which made it even easier as you just cut the old pipes and fit supplied connectors.
Mon Sep 02 2013 6:53am |
