Home > General > Another silly question
rigpig100
2008 Range Rover Sport TDV8 HST Santorini Black
not sure what I have done, but when I put the R/R into reverse, the mirrors go silly, when I put it back into drive, the mirrors go back to the original setting.
How do I stop this ?
Cheers guys
Bob
Post #393043 Wed Aug 28 2013 6:17pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Re: Another silly question
They dip to help when reversing although I didn't like it so I disabled it on mine.
This is done via settings on the dash.
Nik
Unnecessary quote removed 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #393044 Wed Aug 28 2013 6:20pm
rigpig100
Many thanks for that, got a feeling this will end in tears, but will gie it a shot.
Bob
Post #393047 Wed Aug 28 2013 7:11pm
You need to do it for each key too don't forget. 2012 SDV6 - it's missing a couple of cylinders
Post #393048 Wed Aug 28 2013 7:32pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
its pretty easy to change setting mate
Post #393054 Wed Aug 28 2013 7:48pm
rigpig100
if it means getting the book out im da poo.
will get the other half on the job.
Post #393055 Wed Aug 28 2013 7:51pm
simple1
If you go into settings menu on the dash ( engine running but in park) you will find a subject " mirrors dip". If to toggle that with the bottom right button on steering wheel to off they won't dip when selecting reverse. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #393058 Wed Aug 28 2013 8:03pm
Why? Can't you read? Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #393078 Wed Aug 28 2013 11:12pm
Sporting Chance
England 2010 Range Rover Sport TDV8 HSE Santorini Black
Personally I like that function.
Had it on the disco too. Current 2010 RRS TDV8
Gone 2009 D3 HSE TDV6
Gone 50th anniversary Defender
Gone 1992 Defender 200 TDI
Gone 1988 Defender TD
Gone 1979 Series 111 V6 Steve Parker conversion
Post #393268 Fri Aug 30 2013 6:10am
Marsie
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
Turned the dip function off on mine. Was good on the D3 for coming out of the garage but the RRS seems to dip further and points almost straight down Rolling Eyes
Paul
Post #393276 Fri Aug 30 2013 7:24am
mlines
marsie,
You adjust the level of DIP you want by putting them in dip mode and adjusting the mirrors to give the view you want. It then returns to this setting every time. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #393294 Fri Aug 30 2013 8:55am
rigpig100
The only time I really need to move the mirrors are when backing the boat in and out of the slip. will try and get them set up .
Cheers Bob
Post #393304 Fri Aug 30 2013 9:27am
Sporting Chance
Ok I liked this function on the D3.
Switched it on in the Sport and like the mirrors pointed at such a stupid angle it would be impossible to reverse anywhere let alone with a trailer.
Is there some way to set the angle they adjust to?
Jim Current 2010 RRS TDV8
Post #393405 Fri Aug 30 2013 11:33pm
mlines
See my post three above! 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #393438 Sat Aug 31 2013 3:21pm
This, along with almost every other "how do I switch X on/off" type question is dealt with in the manual. Whistle
If you don't have the manual then try looking up your particular model on topix: http://topix.landrover.jlrext.com/topix/vehicle/lookupForm 2012 SDV6 - it's missing a couple of cylinders
Post #393439 Sat Aug 31 2013 4:17pm
