Home > General > Another silly question |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 |
They dip to help when reversing although I didn't like it so I disabled it on mine.
Wed Aug 28 2013 6:20pm |
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 |
Many thanks for that, got a feeling this will end in tears, but will gie it a shot.
Wed Aug 28 2013 7:11pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
You need to do it for each key too don't forget. 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 28 2013 7:32pm |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
its pretty easy to change setting mate |
Wed Aug 28 2013 7:48pm |
Unnecessary quote removed
Wed Aug 28 2013 7:51pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
If you go into settings menu on the dash ( engine running but in park) you will find a subject " mirrors dip". If to toggle that with the bottom right button on steering wheel to off they won't dip when selecting reverse. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Aug 28 2013 8:03pm |
Why? Can't you read? 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Wed Aug 28 2013 11:12pm |
Sporting Chance Member Since: 08 Aug 2013 Location: Oxford Posts: 32 |
Personally I like that function.
Fri Aug 30 2013 6:10am |
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 |
Turned the dip function off on mine. Was good on the D3 for coming out of the garage but the RRS seems to dip further and points almost straight down
Fri Aug 30 2013 7:24am |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
marsie,
Fri Aug 30 2013 8:55am |
Fri Aug 30 2013 9:27am |
Ok I liked this function on the D3.
Fri Aug 30 2013 11:33pm |
See my post three above! 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
Sat Aug 31 2013 3:21pm |
This, along with almost every other "how do I switch X on/off" type question is dealt with in the manual.
Sat Aug 31 2013 4:17pm |
