![]() | Home > General > Low Range Needed or not. |
I have used low range once in 10 years of driving Range Rovers and that was to pull a mini digger out of a bog |
Think of it like this...how embarrassed would you be (including associated YouTube videos and rrs forum mocking) when your car is stuck in a field or unable to pull a x somewhere just because you didnt have low range fitted on what should be the most capable 4x4 made.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9031 ![]() ![]() ![]() |
Agreed mse, for £410 it seems like a no brainer to me... 2012 SDV6 - it's missing a couple of cylinders
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Good point on second hand market so presumably affect on depreciation |
The low range is £400ish, its adding Dynamic bit to a HSE thats £1000's Mike
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
Can you spec low range on the lower spec models or is it only on HSE spec? Now driving a rather smart looking Van |
You can't spec low range on the SE. It's an option on HSE and standard on the HSE Dynamic and AB Dynamic versions. 2012 SDV6 - it's missing a couple of cylinders
