Home > General > Dodgy Cruise Control |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Could be the brake pedal switch. The switch has two actions - the first slight press of the pedal disables the cruise control, a further press then activates the brake lights. Be worth checking the switch. Others on here have said it's a cheap fix and possible to do at home. 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 28 2013 12:05pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4396 |
Generally, either a switch pack or wiring in behind the airbag
Wed Aug 28 2013 2:11pm |
There are a few posts on the Disco3 site about similar problems associated with something called the 'clock spring' which is inside the steering wheel and is (unfortunately) around £300 IIRC. Think it makes the electrical contact from the wheel to the car.
Wed Aug 28 2013 3:17pm |
saty Member Since: 17 Aug 2011 Location: Beds Posts: 227 |
Thanks all for the replies..
Wed Aug 28 2013 4:00pm |
Answers have already been given
Wed Aug 28 2013 6:47pm |
Brake light switch swop never a bad idea as they have a limited life. Order one from site sponsor Duckworth parts and mention the forum to get 10% discount. Cheaper than eBay
Wed Aug 28 2013 7:36pm |
That's a great little how-to Paddi 2012 SDV6 - it's missing a couple of cylinders
Wed Aug 28 2013 7:44pm |
Bodsy cheers pal and paddi thanks for the write up that is awesome. I have ordered loads from Dan in the past so will email him now for the switch and then see what happens after I follow your guide.
Thu Aug 29 2013 3:30pm |
While replacing the switch is always a good idea, due to them being a design, if you had a faulty pedal switch, you would have more issues than just the CC not working properly
Fri Aug 30 2013 5:44am |
Ahh man then it sounds then it could be the wiring like your D3... Can you advise what you had to do to fix it? Cheers DM |
Fri Aug 30 2013 9:46am |
The wiring loom in behind the airbag... |
Fri Aug 30 2013 2:10pm |
DM.. what I meant to say was was the loom replaced or was it just cracked or something? cheers |
Fri Aug 30 2013 2:25pm |
The loom was replaced. Visually, it all looked fine, but obviously a hidden issue someplace. Was not expensive either. £12 inc VAT |
Fri Aug 30 2013 8:46pm |
DM, have got the part number for this.? cheers |
Mon Sep 02 2013 3:59pm |
