Home > Technical > Can anyone identify this? |
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 |
I have got one too, on the drivers side? The connected plug appears to have 2 terminated wires in it as though it is meant as a blank. Cant see where its supposed to go? wondered if it was maybe a brake pad wear connector?
Wed Aug 21 2013 8:32pm |
Found a similar thing behind a headlight and posted a similar question. Disco Mikey ID'd it as an unused part of the loom for TPMS.
Wed Aug 21 2013 8:48pm |
That could be it ,Mine has 2 very short pieces of wire fitted into the plug (as though they have been cut off next to the connector). Maybe a wireless aerial for the TPMS
Wed Aug 21 2013 8:55pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Rear TPMS receiver connector |
Thu Aug 22 2013 6:00am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Cheers guys - now just got to find where it should be fixed
Thu Aug 22 2013 7:21am |
Look at the rear wheel arch liner; there are two holes about halfway up the rear side. The 'fir tree' lug on the connector should be plugged in to either one of the holes from the outside of the liner. No idea what the other hole is for though 2008 MY Java Black TDV8 HSE |
Thu Aug 22 2013 8:28am |
Thu Aug 22 2013 8:49am |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
Yep, that's right Muddy. I had the same thing with my 09, it fell down after a dirt road (winery) trip. I stuck it back in the rear wheel arch housing and it didn't drop down again. I may have helped it with a little tape if I remember. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Thu Aug 22 2013 9:20am |
