Home > Technical > Can anyone identify this?
muddywheels
Milk Float Man
Just washed my RRS and found this cable hanging on exhaust - passenger side Shocked
Now either it was missed by QC on build or Censored dealer has done it when they fitted tow electrics Thud Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #392418 Wed Aug 21 2013 7:37pm
Marsie
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
I have got one too, on the drivers side? The connected plug appears to have 2 terminated wires in it as though it is meant as a blank. Cant see where its supposed to go? wondered if it was maybe a brake pad wear connector?
Paul
Post #392427 Wed Aug 21 2013 9:32pm
Paddi
Found a similar thing behind a headlight and posted a similar question. Disco Mikey ID'd it as an unused part of the loom for TPMS.
Since found one attached by the lug to each wheel arch liner. They are pretty loose so could easily fall out. 2008 MY Java Black TDV8 HSE
Post #392432 Wed Aug 21 2013 9:48pm
Marsie
That could be it Thumbs Up ,Mine has 2 very short pieces of wire fitted into the plug (as though they have been cut off next to the connector). Maybe a wireless aerial for the TPMS
Just got to find out where its supposed to clip up. The connector i have is identical looking to muddywheels picture Thumbs Up
Post #392433 Wed Aug 21 2013 9:55pm
Disco_Mikey
Rear TPMS receiver connector Thumbs Up
Post #392452 Thu Aug 22 2013 7:00am
muddywheels
Milk Float Man
Cheers guys - now just got to find where it should be fixed Thumbs Up
At least I know they didn't forget to connect abs or something critical Whistle Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #392457 Thu Aug 22 2013 8:21am
Paddi
Look at the rear wheel arch liner; there are two holes about halfway up the rear side. The 'fir tree' lug on the connector should be plugged in to either one of the holes from the outside of the liner. No idea what the other hole is for though Rolling Eyes 2008 MY Java Black TDV8 HSE
Post #392464 Thu Aug 22 2013 9:28am
muddywheels
Milk Float Man
Cheers Very Happy
Don't know what I'd do without this forum Bow down Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #392467 Thu Aug 22 2013 9:49am
BKHK
Yep, that's right Muddy. I had the same thing with my 09, it fell down after a dirt road (winery) trip. I stuck it back in the rear wheel arch housing and it didn't drop down again. I may have helped it with a little tape if I remember. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #392472 Thu Aug 22 2013 10:20am
