Home > Technical > Air con compressor
Preston-rr
United Kingdom 2010 Range Rover Sport SDV6 HSE Sumatra Black
Air con compressor
Hi all, my air con isn't cold. I had it regassed was ok for 1 day. Went back said it could be the compressor but let's try the in can pipe sealer stuff, forgot the technical name. Worked for maybe a week now to cold again. Is it my air con compressor that needs changing? Can they be fixed? If not how much is a new one?
Cheers 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #392421 Wed Aug 21 2013 8:13pm
flack
I doubt its the compressor it's more likely to be the condenser or dryer that has a leak in it..when they did the regas did they do a leak check with a uv light source..
Flack Thumbs Up
Post #392422 Wed Aug 21 2013 8:39pm
Disco_Mikey
As Flack says, it is does not stay cold, there is a leak somewhere. Most common is the condensor, and very reasonably priced from site sponsor Advanced Factors Thumbs Up
To confirm though, you need a U/V dye put into the system , and checked with a U/V light to highlight any leaks Thumbs Up
Post #392453 Thu Aug 22 2013 7:02am
