Home > Faults & Fixes > Gearbox Fault
Kenzi
Australia
Gearbox Fault
Post #392021 Sat Aug 17 2013 11:30am
drdelrrs
Try a hard reset (battery disconnect).
Post #392023 Sat Aug 17 2013 12:07pm
Kenzi
Australia
Just out of interest, what would this do?
Post #392055 Sat Aug 17 2013 6:46pm
Paddi
Hard reset powers down the various ECUs and seem to remember reading in the workshop manual that it clears the engine adaptations which may sound daft but all the ECUs interact so it may help if one of them has its knickers in twist. Other daft sounding suggestions that can cure many faults include checking your brakelight bulbs are working and are OE parts; fully charging the battery with a decent smart charger and, changing the brake light switch. Another popular fix is checking the pivot of the linkage on the side of the gearbox which has a habit of seizing (you might notice this as a stiff feel to the gear lever - it should move freely. You didn't mention if the garage found any fault codes but it would be important to know if there were any found. 2008 MY Java Black TDV8 HSE
Post #392060 Sat Aug 17 2013 7:26pm
Kenzi
Australia
Thanks for clearing that up. The linkage is fine as this has been checked and the gears move freely.
There was error codes that popped up, I will post these when I find them out as I dont have the sheet with me.
Post #392063 Sat Aug 17 2013 8:00pm
Kenzi
Australia
Post #392242 Mon Aug 19 2013 6:59pm
flack
You need to Contact Liam on the forum and explain your situation and that the car is just out of warranty and see if he can help in any way it should not fail at this mileage.
http://www.rrsport.co.uk/forum/topic32200.html?highlight=liam
Flack Thumbs Up
Post #392245 Mon Aug 19 2013 7:43pm
Multiplate clutch E is used in gears 4, 5 and 6 so that would seem to match with the speeds it shows the error.
As flack says, it must be worth approaching LR (and maybe even ZF) as that gearbox shouldn't fail after such a short life.
It might also be worth, once you get the thing sorted, getting the LR Approved extended warranty. 2012 SDV6 - it's missing a couple of cylinders
Post #392257 Mon Aug 19 2013 9:11pm
Paddi
That DTC doesn't sound good. If LR can be persuaded that you have a case and help out that's good.
But is complete replacement of the gearbox always the only option?
Could a good transmission specialist just replace the faulty part? If for example the clutch isn't operating properly because the mechatronic isn't activating it correctly then could a good repairer just fix the mechatronic? 2008 MY Java Black TDV8 HSE
Post #392306 Tue Aug 20 2013 11:50am
drakkarnoir
Germany 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
I have the same issue
Dear Kenzi,
I have the same issue on my gear box. Error code: P2704-07 TCM Gear friction element E
Could you fix this issue?
Range Rover Sport HSE
Year of manufacture: 15.03.2010
km driven: 86.000
Please let me know asap.
Thanks in advance
Patrick
Post #404189 Fri Nov 29 2013 10:56am
Kenzi
Australia
I have just had the gearbox replaced as it was the only option.
There was bearings etc worn inside the gearbox... at 22,000 miles and has cost me £4000!!!
Not happy!
Post #404324 Sat Nov 30 2013 12:18pm
jonny gogo
2007 Range Rover Sport TDV8 Autobiography Bali Blue
GEAR BOX JUDDERING AT LOW SPEED !!!!!!!
HI
CAN ANYONE HELP WITH THIS PROBLEM.....
2007 RANGE ROVER SPORT 3.6 88,000 MILES, WHEN YOU SELECT DRIVE AND TAKE YOUR FOOT OFF BREAK PEDAL THE CAR HAS A SLIGHT JUDDER THIS ONLY HAPPENS EVERY SO OFTEN NOT ALL THE TIME !!! ONCE YOU APPLY POWER THE CAR DRIVES PERFECT. IM THINKING OF DOING A GEAR BOX FLUSH ...... WHATS YOUR THOUGHTS ?? HAS ANYONE ELSE HAD THIS PROBLEM IF SO CAN YOU HELP PLEASE .
JONNY Big Cry
Post #404740 Tue Dec 03 2013 6:40pm
Paddi
Hi and welcome,
Not heard of quite that fault before. If the gearbox fluid has never been changed then a flush and filter change would be a good thing regardless. Is the shifter a bit stiff? There is a pivot on the actuator cable on the outside of the gearbox that seizes and the parts to renew are only about £13 so would be good idea to change that too. A good independent garage would do both jobs for you and could perhaps do a diagnostic check for any fault codes. 2008 MY Java Black TDV8 HSE
Post #404764 Tue Dec 03 2013 9:45pm
jonny gogo
Hi paddi
Thanks for replying to my message , it's booked in tomorrow for flush fingers crossed it fixes the problem. It's a strange one as it only happens when you select drive then take your foot off break once you apply power car runs perfect !!
Post #404765 Tue Dec 03 2013 9:51pm
Just a thought, the judder isn't the EPB disengaging is it? 2012 SDV6 - it's missing a couple of cylinders
Post #404771 Tue Dec 03 2013 10:16pm
