Home > Faults & Fixes > Gearbox Fault |
Kenzi Member Since: 24 Jun 2013 Location: Perth Posts: 101 |
Sat Aug 17 2013 10:30am |
Try a hard reset (battery disconnect). |
Sat Aug 17 2013 11:07am |
Just out of interest, what would this do? |
Sat Aug 17 2013 5:46pm |
Thanks for clearing that up. The linkage is fine as this has been checked and the gears move freely.
Sat Aug 17 2013 7:00pm |
Mon Aug 19 2013 5:59pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
You need to Contact Liam on the forum and explain your situation and that the car is just out of warranty and see if he can help in any way it should not fail at this mileage.
Mon Aug 19 2013 6:43pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9013 |
Multiplate clutch E is used in gears 4, 5 and 6 so that would seem to match with the speeds it shows the error.
Mon Aug 19 2013 8:11pm |
That DTC doesn't sound good. If LR can be persuaded that you have a case and help out that's good.
Tue Aug 20 2013 10:50am |
drakkarnoir Member Since: 29 Nov 2013 Location: saarbrücken Posts: 1 |
Dear Kenzi,
Fri Nov 29 2013 9:56am |
I have just had the gearbox replaced as it was the only option.
Sat Nov 30 2013 11:18am |
jonny gogo Member Since: 03 Nov 2013 Location: Darlington Posts: 15 |
HI
Tue Dec 03 2013 5:40pm |
Hi and welcome,
Tue Dec 03 2013 8:45pm |
Hi paddi
Tue Dec 03 2013 8:51pm |
Just a thought, the judder isn't the EPB disengaging is it? 2012 SDV6 - it's missing a couple of cylinders
Tue Dec 03 2013 9:16pm |
